I would love to gain the insight and expertise from any A1 experts in the group. I am building as a "therapy" an A1 GTI car to Solo and Autocross. Eventually would like to participate in track days, but not sanctioned/class racing.
Presently, the car is in pieces and I am accumulating the proper parts for assembly. I have completed the engine rebuild and tranny/lsd install.
What I need to sort out relates to the suspension, brakes, roll-cage, tire/wheel package, and data-acq. system.
With regard to the front control arms and rear spindles, can they be adapted to use Porsche spindles/hubs to accept P-car brakes and 5 lug hubs? The a-arms are the same as early 944 control arms, so I thought they might bolt up. Anyone have experience with parts interchangeability? What has worked for others on improving brakes? I did the swap to rear disc off a Scirocco, but I would like to "over-brake" the car. Additionally, I would love to use phone dial wheels from same make. What off-sets will I need to run to avoid clearance/rubbing of suspension and arches. I may use coilovers, as I have heard with the tighter springs, you gain clearance on the inside.(is that true?)
Roll-cage is a tough thing to shop, as I suspect it's best to get locally given shipping costs. I understand the benefits of bolt vs. weld in, so I guess it comes down to geometry. Any suggestions.
I will likely not use the factory gauge cluster, rather I would shop a DA system that has graphical display of tach, speed and allow for export of data. Any favorites out there under $1-2000?
Thanks for any and all help!
Jack "NordTexan" Ormberget
Maverick Region PCA, SCCA, 2004 & 2005 Orbit Racing Team 24Hr Daytona
[url=http://www.cardomain.com/id/NordTexan]My Garage--NordTexan
[url=http://www.cardomain.com/ride/2279559]My Project
