Hi guys,
from my reading of the rules, all I can find about the shift mechanism is that the shift lever can be bent above the tunnel. So, no replacement of the shift lever to give a shorter throw - is that a correct interpretation?
thanks,
bruce
Hi guys,
thanks,
bruce
well, I went over the Rules & Regs forum where I should have looked first and see that short shifters are not legal.
thanks,
bruce
Hi guys,
thanks,
bruce
gotta love self help programs!!well, I went over the Rules & Regs forum where I should have looked first and see that short shifters are not legal.
thanks,
bruce
marshall
Instructions for legal short shifter:
1. Remove shifter from transmission
2. Clamp shaft shaft in vise just above pivot
3. 2.5 inches down from knob threads heat shift shaft with torch until cherry red
4. Bend shaft 180 degree toward the front of the car (shouting of profanity for burning fingers because you didn't put your gloves on is optional).
5. Remove beer from cooler and open, soak burned hand in cooler and drink beer, holding in unburned hand, while shaft cools.
6. 2 inches down from the first bend in the shaft heat shaft once again until cherry red and bend shaft 180 degrees to the rear.
7. Incase you didn't learn the first time repeat step 5
8. Remove shifter from vise.
9. You should now be holding a workable shifter that is 2 inches shorter than the original. and if you did it right you have enough shaft above the bends to screw the knob back on.
10. Reinstall shifter in transmission.
11. Admire your handy work.
12. go to the medicine cabinet for aspirin/tylinol/motrin or your painr reliever of choice and and burn balm.
Your Redneck Racing short shifter is now ready for use.
Jerry
Lone Star Regional Executive
Lone Star Tech Chief.
seems to me you're going to make it 4" shorter
steve saney
it-7 /it-a #34
Steve,
You obviously need to repeat basic REDNECK engineering at the local night trade school. :P
It was bent down two inches but it was bent back up two inches so it can only be two inches shorter.
(OK, in the real world it would be 4" shorter but then it wouldn't be redneck now would it?)
Jerry
