how many SCCA nerds on the end of a pin?
I don't know, but they sure could argue about it forever.
(valued reader: this, of course, does not apply to you.)
Let me clarify. I wasn't proposing a change. I was asking if things would be different right now, and if this conversation would be happening, if the rule had remained as [I believe] it was when IT was born.Originally posted by Bill Miller@Dec 14 2005, 07:49 AM
Looks good Kirk, the only thing I would add would be the following: ...
The "exact equivalent" language was inserted as a response to some pushing of the rules, and so is not a reflection of the original intent - WHATEVER that might have been.
I had hoped to avoid it because it isn't part of the issue. Greg kind of got called out personally so, in a show of solidarity with him, I need to go on record: I am NOT going to make any claims here about what size pistons I am putting in the block that's currently at the machinist (because you will either believe me or not, based on your individual predilections) but suffice to say that (a) I made my decision AFTER this conversation began, ( they have VW logos on them...
I hope most of you know me well enough to believe that I'd be in the thick of this conversation even if I were racing a Pinto with a wrecking yard engine.
Kirk,Originally posted by Knestis@Dec 14 2005, 05:20 PM
[snapback]68284[/snapback]
You're switching to GT Pinto?????
Pinto....The only IT car that should have a fuel cell required on the spec-line.Originally posted by Bill Miller@Dec 14 2005, 02:45 PM
Kirk,
[snapback]68291[/snapback]
GTL Nissan Sentra
DP 240sx
Vintage BS 510
ITS 240z
http://www.saveclubracing.com
[snapback]68276[/snapback]
George Roffe
Houston, TX
http://www.nissport.com
From '06 GCR...
The installation of a resistor is alowed between the sensor and the OEM wiring harness. :P Going WAY back in this thread.
