Results 1 to 4 of 4
Thread: IT-7 spec tire question
    Sep 2004
    Sugar Hill, GA
    140
    Right now I'm under the impression that the spec tire for IT-7 is only for SARRC races. Is this correct? I was planning to run the ARRC, PRO-IT and ECR races on a non-spec tire. Anyone know for sure what the deal is here?
    ReSpeed
    2006 ARRC IT-7 Champion
    2006 PRO-IT IT-7 Champion
    Aug 2005
    2
    The spec tire is for all Southeast IT7 races SARRC, ECR and regionals. As for the Pro IT and ARRC races are up to Atlanta I guess. But I would thank Pro IT would be spec tires and The ARRC on any DOT tires with the other cars from outside the Southeast.
    Jun 2004
    Raleigh, NC
    195
    [snapback]62364[/snapback]
    OK, I am frequently (and accurately) labeled as a smart-@$$, but I'm trying to ask this seriously;
    Since the SIC has already happened, the "Goblins" race coming up at VIR in a couple of weeks is a 2006 SARRC event. However, the ECR and CCPS races count towards 2005 points. I am absolutely certain that the SARRC will enforce the spec tire rule. What about the ECR and CCPS????
    (I probably won't use them, but I *DO* have a set of Hoosiers that I could potentially run in the ECR)
    Mike Spencer
    ITA/7 RX-7 #60
    IT7R RX-7 #37 (build in process)
    1990 Classic Red Miata
    2004 "Winning Blue" RX-8
    Jan 2005
    mcdonough,ga
    71
    The last bit of information I got from the ARRC chairpeople is any DOT tire will go for the ARRC race. That is for all classes except for SM. Russ call fletcher to find out about PRO-IT.
