Lookiing ro R180 3:90's in the Virginia area
Hey guys,
I am looking for a R180 3:90 gear set up in a diff . Its for a EP racer up in Virginia . Let me know if you know of one .
Thanks,
Mike
Zdriver.com
I wish you the best of luck, the 3.90:1 r180 was (supposedly) only used for 6 months on the front of the 720 4x4 pickup.
I have one that came with my car as a spare that I'm told is an R180, but it may really be an R190, which I'm told is more common, or even an R160. Without taking it apart I don't know how to tell the difference. It looks like it will bolt to a R180 moustache bar, if that helps. If you have any insight here let me know, I'll check for you. The ring gear is stamped 39:10 so it is definitely a 3.90:1. It is not an R200, those are easy to spot.
Anyway, I'm in New Mexico, email me if you're interested. I don't mind shipping.
x-ring(at-sign)zcar(dot)com
Ty
Edited for fat fingers.
[This message has been edited by x-ring (edited September 20, 2003).]
There is one being offered on ebay right now. I already have one or I'd be bidding on it.
DC
DC
Mike is trying to find one for a guy that doesn't want a welded rear...
I already found him one an hour from his house but he won't use a welded rear....
I don't find any on Ebay unless you are talking about the R-200's, one with the Phantom "Slip" and one Z31 3:70....
Unless you are talking about the 200sx 4:11 in which case that's already gone..
You're right. I was bouncing between sites. The one I saw was in the classified section of this site...and it is welded.
DC
i'm in the market for an r-180 with 3.90 also. i don't mind if the spiders are welded. any leads would be appreciated. [email protected] or 980-621-1988.
You might still be able to get the ring/pinion set from Nissan.
Courtesy Nissan
1-800-527-1909
www.courtesyparts.com
Sells NISMO competition parts. The R180 ring/pinion will fit any R180 carrier.
Its not cheap though.
Tom
Actually, Wolf Creek racing has had a new 3:90 R&P advertised on their site for quite a while for 300 bucks and a new 3:70 for 275.
http://www.wolfcreekracing.com/classified.htm
