Results 1 to 5 of 5
Thread: Gen II base alignment
    Jun 2004
    Greenville, SC
    102
    Default Gen II base alignment
    I'm new to ITs. Have what appears to be a nice GII RX7. I need recommendations for a basic alignment set up.
    Interested in Toe, camber and any wedge folks have found to be beneficial.
    Thanks
    tbtapper
    Oct 2002
    Wandering the USA
    1,341
    I'm not an expert, so take this with a grain of salt.
    Camber will depend on your tires, and perhaps on your springs and sway bar. Measure tire temps with a probe pyrometer to set the camber properly. Inside ~15 deg hotter than outside is about right. I'm using Hoosier R3S04s, and am currently at -3.0 degrees front and -2.0 degrees rear. Still measuring to find out where I'm at. Inflation is correct when the center temperature is the average of the inner and outer.
    Front toe - from 0 to 1/8" toe out.
    Rear toe - ~3/16" toe in.
    Marty Doane
    ITS RX-7 #13
    CenDiv WMR
    Floyds Knobs, IN
    1,093
    Depends on tires, track, etc. But with the old 03 Hoosiers...
    -2.0* negative camber in front
    -All the caster you can get while maintaining the same amount on each side
    -1/8" toe out
    -1.5* negative camber in rear
    -0 toe
    Chris Ludwig
    08 ITS RX7 CenDiv
    Oct 2002
    Wandering the USA
    1,341
    Darn. Chris beat me again.
    Marty Doane
    ITS RX-7 #13
    CenDiv WMR
    Jun 2004
    Greenville, SC
    102
    Thanks for the replys. Car came with a couple of sets of Goodyears. No idea the no. of heat cycles or sessions.
    I figure I'll run the casings off the Goodyears getting to know the car and various tracks.
    Once I'm not a "liability" on the tracks I'll probably go with the Hoosiers and get serious with alignment and set up.
    Don't have a pyro yet just looking for a baseline set up to begin with.
    tbtapper
