I'm finally getting to corner weight my car, and adjusting ride height has proved difficult.
What are you ITA RX-7 guys running for ride heights? I've been recommended to get the car to the 5" minimum, but theres just no way. Tire contact is a huge problem at any height approaching 5".
I'm running 205/60/13 Hoosiers, based on their recomendation that that size fit the required 7" rim the best.
I note that Hoosier builds a 225/50/13 that has similar width dimensions, but is an inch smaller in diameter, which would help tremendously with clearances.
I run Revolution rims, with a backset of 4" (near as I can measure!)
But Hoosier recomends a rim of 8 or 9 inches, although the dimensions they list are from measuring on a 7 inch rim!
So, the questions:
1 What tire sizes are you guys running?
2 What ride heights have you been using? Are these equal side to side? front to rear?
3 What wheels and backset?
4 How close to 50% cross weight can you get to?
Thanks for any and all help!
ITA 57 RX-7
[email protected]
