Originally posted by Wayne:
Retrofit? You have a design that makes a single release point?? Both pins are pulled at the same time??
Wayne
Wayne,
No. Technically that would not satisfy the single release requirement; you would have two release points.
I'm referring to a change in the Isaac belt connector. Rather than capturing the belt with the mechanism, the belt slips into a "C" shaped component. You could either disconnect at the helmet as you do now, or drag it out the window, looking like a human TV antenna.
BTW, this would not affect the performance of the Isaac system in controlling tension loads, but the increased friction at the belt connector would slightly increase early compression loads. We crashed a similar design at Wayne State so we know it's very safe.
Kirk,
You seem satisfied with your beta-tested, Enduro Spec model. What length would you recommend for the lanyard? We can have them made up in time for the new season.
Gregg Baker, P.E.
Isaac, LLC
http://www.isaacdirect.com
[This message has been edited by gsbaker (edited January 15, 2005).]
