Originally posted by Joe Harlan:
Ron, in reading all of your posts the last couple of years I will say this. Right now you say you are doing the JH for fun and because you are a JH lover. Most start out this way. I contend that if you JH is not competitive in ITS you will not be satisfied in the end just to make laps. You will either A: try to get the car adjusted or B: try to get the car moved. This is not a slam in any way. You posts indicate that you are a driver in the true spirit of the word and I take from that that second is not much of an option for you. I think the idea if class it out of spec and adjust is what kills most of the new cars in IT. Looking at the new found interest in the NEON, SER, NX2000's should be an indicator of that. Once they were classed proper there is now cars being built.[/B]
