Originally posted by lateapex911:
Experiment at the front with your caster. Keep going backwards at the top (increasing negative caster, say from -1 degree to - 2 degrees then to -3 degrees) until it gives you the feel you are looking for. The FWD guys may have some specific figure that will work in some FWD applications, and I would think that might be a good place to start. In general, the more neg caster (-3 degrees, for example), the more self centering the steering becomes, and the better the steering feel.
