Help me pick a kill switch
I know it's kinda silly to post asking "which kill switch" to put in a car....BUT....it seems that, of all the things we do to cars to get 'em ready to race, the one thing I hear horror stories about is failed/flaky kill switches.
I'm planning a two-pole "ground the alternator too" type - unless someone has a compelling argument otherwise.
The real question: are there particular brands, styles or models that seem to hold up better than others?
This will be going in my Spec Miata (making it legal for next year so I can finish this year at the ARRC ), likely mounted just inside the passenger window on a plate mounted to the rollcage. It will NOT be used on a regular basis (unless I should in the interest of keeping it working??) - the ignition in the car works just fine.
I figure you guys in IT land have fought through this a hundred times - may as well tap the knowledge.
Jarrod
Jarred.. I was poking around this site just recently concerning kill switches also.
If you want to find all the posts concerning this issue.
This is what I did. I went to the (search) option and performed a searh for KILL SWITCHES then I wanted to find more. So I went to the (Forums Tech Talk and changed the (show topics from las9t 45 days)) to (show all topics.)
Then I clicked back each sheet and scanned for any topics containing the wording (switches)(kill switch) (wiring) (switch wiring).. There is a post on page 4 or 5 that has a link where someone has drawn out diagrams for wiring Kill switches..
Best of luck,
Toodles,
Stacey_B
Toodles,
Stacey_B AOL IM: SCCAStaceyIB 1990PGL SCCA STSL "Girls Do It Better" Cal Club T&S, BWRP,WS,Lag,Hallett www.scpoc.com : www.probetalk.com Racing is my life. Winner One Lap of America 2003- SSGT2 class 1996 Ford Probe GT.
The longacre switch is a pretty nice unit. Definitely get one of the more expensive switches as the $20 two poles tend to not work when you get the 2 minute grid warning
I've got the "6" pole switch that's available at Racer Wholesale and so far it seems like a good solid switch, but it was on the car when I bought it and I've only used it for one weekend so far.
Make sure you keep the wiring directions that come with it, as there is about 3 days worth of websearches and scratching your head if you don't have them
Scott
It's not what you build...
it's how you build it
<A HREF="http://www.pfmracing.com" TARGET=_blank>
www.pfmracing.com </A>
The answer is LONGACRE for ~$30. They offer a 2 Pole switch that meets our needs. There have been a number of threads on this, but the wiring is very simple and meets all the rules. Mine works perfect. If you need help with it drop me an e-mail and I'll try.
'89 CRX Si-SCCA ITA #99
'99 Prelude=a sweet song
Having had one flake out on me this weekend (and seen others go bad at odd times) I do not think it's a matter of brand, but rather putting it on a replacement schedule.
The problem is that it is an electrical element and can be exposed to the elements, so the schedule (while measured in years) is a tough one to pick.
Carry a spare (or a set means of quickly by-passing)
we use the longacre switches in our ambulances
we turn em on and off 20 times a day and they last for quite a few years..
I just installed mine in the prelude..
Jarrod,
I too have the longacre two pole with alternator kill. It was pretty easy to put in, and I have had no issues with it to date.
Did you go to the Pro-Spec Miata weekend @ HPT?
How did you do?
I'm getting ready for Memphis right now, any plans on attending?
Let me know, and I can send you some docs on the kill switch and the wiring diagram.
JJ
#62 ITC
Thanks to all - Longacre two-pole switch is on order.
JJ - I skipped the weekend at HPT. REALLY wanted to do it, but decided the home life and getting stuff ready for the ARRC would be a better idea. Found the spare tire, found a couple more interior (metal) panels - the car begins its stint on "Weight Gainer 3000."
Won't make Memphis or St. Louis - Atlanta is gonna be my big blow-out. (Hopefully not literally. )
You still considering Atlanta?
Jarrod
The Longacre, Moroso, and Intercomp switches are all made by the same folks.
It's like some one said. "it's an electrical component, and in a harsh inviroment" It is a good plan to carry a spare and to replace it it every year.
Also pop the extra $5 bucks or so for the 4pole that is designed for the altenator.
earier to hook up. and less chance of it not killing the engine
