Results 1 to 7 of 7
Thread: Stitch welding seams
    Sep 2012
    6
    Default Stitch welding seams
    Can anyone shed some light on whether or not you can stitch weld the seams on the chassis
    Mar 2001
    Connecticut
    7,343
    Quote Originally Posted by Roy View Post
    What category?
    Improved Touring? No. Why not? Because it doesn't say in the regs that you can do it ("If it doesn't say you can, then you cannot"; 9.1.3.D).
    Explicitly allowed in Super Touring (9.1.4.C.2)
    Not my circus...not my monkeys...
    Sep 2012
    6
    So yes for STL but no for ITS
    Sep 2012
    6
    Not sure why it would be ok in one category but not another. It would seem to me that it would make the chassis stiffer but perhaps safer as well.
    Mar 2001
    Connecticut
    7,343
    Correct.
    Different categories have different prep regs. Otherwise they wouldn't be different categories.
    Everyone here has heard the "safety" canard as a support for a preferred rule change. It's been trotted out many, many times. No point in bringing it up lest we smile toward you and say "bless his heart..." If you think a particular ruleset is unsafe then it is your responsibility to not participate in that category and seek out one that meets your personal safety needs.
    Sep 2012
    6
    Quote Originally Posted by Greg Amy View Post
    Correct.
    I don't think current rules are unsafe in IT just thought if you can make it stronger without spending a bunch of$$$ then why not. Just like in categories with their own set of prep rules you have some that will prep to the max and others not so much, the same can be with how much stitch welding you want to do. I just look at my car and see so many seems that are easy to get to just makes sense to stitch weld them.
    Mar 2001
    Connecticut
    7,343
    The genesis of Improved Touring was as a spur of timed-out Showroom Stock, back in the days when Showroom Stock was "showroom stock". That included stock suspension, stock wheels, stock brake pads, stock seats, stock steering wheels, stock pretty-much-everything. About the only thing we could change was tires, add the bolt-in-only cage, harnesses, go racing. Cars were only eligible in the category for 7 years.
    Improved Touring pulled from that whole restriction a series of limited modifications, mostly limited to common bolt-on street upgrades. And in fact, the original regs required the cars to still be street-drivable.
    As such, IT is, and for the foreseeable future will be, an intentionally-restrictive category.
    Attached Files Attached Files
