As the title says, I'm selling my CRX to make way for my next project. I've had this car since 2011, won the 2012 NASA PTE National Championship with driver Eric Waddell, driven by Lee Grimes at the 2012 ITFest. Pics available upon request for anyone seriously interested.
Engine
Fresh .020" over bottom end with only 1 race weekend
Pure Tuning IT-legal head with 1" port match, valve job, Hondata IM gasket, also 1 race weekend old
Balanced & Blueprinted injectors by Injector Pulse
Unorthodox lightweight crank pulley
AEM IT-legal CAI
DC 4-2-1 header
2.5" race exhaust
Transmission
Fresh seals and inspected by Mista Bone last offseason
4.93 GearX Final Drive
MFactory metal plate LSD
Suspension
KONI 8041-Race Shortenned & Race Valved shocks with 550F/800R spring rates
Ground Control extended top hats with spherical bearing adjustable height adjustment
Progress spherical bearings in radius rod, front LCAs & rear LCAs installed by Ruck Racing in 2010 for previous owner
PCI trailing arm bearings installed by Ruck Racing in 2010 for previous owner
Special Projects adjustable rear UCA's with sphercials - legal for HC & PT, also comes with stock UCAs for IT-legal
Special Projects adjustable toe links with sphericals - legal for HC & PT, also comes with stock toe links for IT-legal
Suspension Techniques adjustable rear sway bar, front sway bar removed
Chassis & Brakes
'91 CRX Si with 8-point welded cage originally built by MSN with NASCAR-style door bars on driver's side
Kill switch
5" tach
water temp, oil pressure gauges
New belts & window net for 2014 season
Cobalt XR2 front & XR5 rear brakes
Stainless steel braided brake lines with Motul brake fluid
Buyer has choice of multiple racing seats
MOMO race steering wheel with NRG quick-release
Wheels & Tires
4 - 15x7 Konig Dial In (gloss gold) with used 205/50/15 Toyo RR tires
4 - 14x7 Panasport (silver) with used 225/50/14 front and 205/55/14 rear Hoosier R6 tires
4 - 14x7 Panasport (copper) with used 225/50/14 Toyo RA-1 full tread rain tires
Spare hoods, rear hatches, doors, etc. This car is fast and reliable and ready to race!
Asking $9,000, located in Centerburg, OH
[IMG][/IMG]
Cage pics found here: http://classifieds.racerconnect.com/details.php?id=474
