I use battery cables from E30 or E36 BMWs with trunk mounted batteries. They are $7 from Pull-a-Part. The E30 battery cable can be removed in < 5 minutes.
_____________________
Mike Taylor
1995 MX-3 LeChump/ITX
Any suggestion on local sources for the welding cable? I know that a welding supply store sounds like the obvious answer, but I've checked 2 of them near me and neither had any bulk cable. I could buy a grounding cable and cannibalize it, but that proved to be pretty expensive.
If looks like Advanced has #4 and #2 battery cables in up to 6 ft lengths with a battery terminal on one end and a ring terminal on the other end for about $16. A similiar sized "starter" cable with ring terminal on both ends for the return run is about $9. This seems like a pretty cheap alternative and kinda like the easy button. Any thoughts?
any general supply store, electric, some army surplus, etc.. shops have the cable. find a weird old bearded man with a beat up old japanese pickup in your area and ask him. or a fat sweaty guy with button up shirt. either will know the nearest stroe for such things. inch to inch you will pay a lot more for the advance cable but they do work for a quick and easy fix.
McMaster-Carr has a warehouse in Atlanta which should give you overnight ground shipping. Great place to find stuff like this. Click here to view their welding cable selection
Any local farm or tractor supply will have welding cable as well. Heck, there's a grocery store (and farm supply) in Alvin, TX town that carries more metric hardware and welding supplies than all of the local auto parts and big box 'hardware' stores combined.
I was looking for a handful of 12x 1.5mm fasteners the other day and the only place I could find them was the farm supply. Advance Auto, autozone, NAPA, Oreilly, Home Depot all gave me blank stares. crazy.
Houston Region
STU Nissan 240SX
EProd RX7
Tractor supply. Good idea.
