Results 1 to 20 of 24
Thread: Master Switch Location
    Jan 2010
    Houston-ish
    932
    Lots of SM guys and my RX7 has it mounted on the right side of the main hoop just inside the window.
    A Miata is small enough that most people can reach it in that location while belted in.
    I can't reach it in my RX while belted in, but it's easy to see and access by corner workers-- assuming you're not on your side against a tire wall. I plan to relocate mine to a more easily reachable location- maybe just farther inside the cage- because this car is wired such that gauges and some 'other stuff' are active as soon as the switch is turned on. Maybe I should just fix that part.. lots of little things on this new car that I'd do differently.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Oct 2002
    Wandering the USA
    1,341
    Driver's side to the left of the dash mounted to the upper door bar. Easily accessible through the window, even with the net up. I wouldn't feel safe if I couldn't reach the switch while belted in.
    Marty Doane
    ITS RX-7 #13 (sold)
    2016 Winnebago Journey (home)
    Sep 2001
    hampden,ma.usa
    3,083
    Quote Originally Posted by Eagle7 View Post
    +1 that is what I did the second time.
    dick patullo
    ner scca IT7 Rx7
    Quote Originally Posted by dickita15 View Post
    I also moved mine from next to the rain tray outside the cockpit to inside to the left of the dash, much more convenient.
    Jason Carroll - NER IT7 #07
