Results 1 to 14 of 14
Thread: 350z in ITR
    Apr 2001
    Orlando, FL
    185
    Default 350z in ITR
    Is there a chance of a 2004 Nissan 350z being classed in ITR. Stock HP is 287. Was looking at a T3/ Nasa Spec Z 350z and wanted to see if there is a future in IT with it.
    Hammer
    CFR
    ITA Nissan 240sx #56
    2009 Nissan GTR
    2010 Nismo 370z
    http://www.ReedNissan.com/
    Oct 2004
    Northeast
    7,031
    Doubtful. 240hp is the upper limit now of a stock S2000 - and the only reason that car 'fit's' is because it's already making that out of a NA 2.0/2.2 and the IT mods don't help it much. Makes less whp and more weight than a 325 Bimmer.
    For funzies, it would weigh about 4035lbs given the target power to weight of the class.
    Andy Bettencourt
    New England Region 188967
    Jul 2004
    Raleigh NC
    3,682
    No way that car is going into ITR. The low-hp cars in ITR are at 190 stock hp, so a 100hp spread would be too much for the class.
    Besides, given IT's questionable status in the SCCA I think I'd race it over in NASA.
    Apr 2001
    Orlando, FL
    185
    Any more talk of an IT class above ITR
    Hammer
    CFR
    2009 Nissan GTR
    2010 Nismo 370z
    Apr 2008
    1,499
    Stu ?
    Sep 2008
    Weare, NH
    483
    ...it would weigh about 4035lbs given the target power to weight of the class.
    Glenn Lawton
    GSMmotorsports
    #14 ITS RX7
    NARRC ITS Champion 2012
    NERRC ITS Champion 2013 12 11 10 09 08
    NERRC STU Champion 2010
    __________________
    Jul 2004
    Raleigh NC
    3,682
    Quote Originally Posted by Hammer View Post
    They're always talk. And then there is the reality of IT, what the ITAC can effectively do, and the station of IT in the SCCA.
    Dec 2001
    raleigh, nc, usa
    5,251
    No, significantly more power than the stock power targets for ITR. Like Andy said it would be unraceble in ITR at its spec weight.
    There is talk of a class over ITR. Whether it happens or not I don't know. The ITAC has not focused on that in a while.
    NC Region
    1980 ITS Triumph TR8
    May 2003
    Colchester, CT, USA
    2,120
    Quote Originally Posted by StephenB View Post
    Stu ?
    STO. It's got a 3.5L
    Cool cars though (as an owner of a G35 Sport Coupe) and love the sound when they run in Touring (3?)
    Jeff L
    ITA Miata
    2010 NARRC Champion
    2007 NERRC Championship, 2nd place
    2008 NARRC Championship, 2nd place
    2009 NARRC Championship, 2nd place
    Oct 2001
    New Jersey
    516
    Stu ?
    Quote Originally Posted by JLawton View Post
    Except STO went away
    STO = T1 or GT2
    STU may work. From the Super Touring Purpose on Philosophy in the GCR:
    Super Touring Under (STU) vehicles are mid-level multi-purpose performance cars of 3.2 liters and under. Case-by-case approval of engines over 3.2 liters from “Pony Cars” or “American Iron” with stock camshaft lift at a heavier weight will be considered. No engines over 4 liters shall be allowed under any circumstances.
    It would be worth sending a letter to the CRB if you were interested.
    Terry
    Apr 2001
    Orlando, FL
    185
    I was looking to try and stay in IT with a newer Nissan. The IT field at the Turkey Trot Sebring was 70+ cars. So far the Majors race at Sebring only has a couple STU or T3 cars entered and the small fields don't excite me. I will keep racing the ITA 240sx for now.
    Hammer
    CFR
    2009 Nissan GTR
    2010 Nismo 370z
    Jul 2006
    Sunnyside, NY
    1,196
    This response is so timely. Well crafted as well.
    Demetrius Mossaidis aka 'Mickey' #12 ITA NESCCA
    '92 Honda Civic Si
    STFU and "Then write a letter. www.crbscca.com"
    2013 ITA NARRC Champion and I have not raced since.
    Jan 2010
    Houston-ish
    932
    ...you can install a VQ30 from a Maxima and run the 350 in STU at 3300lbs.. I'm not sure if you can de-stroke it using OEM parts.. there's a line item in the STU rules about the 3.0K in a 350Z. the easy button for that would be to use a Maxima longblock with 350Z externals.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Dec 2008
    Orlando, FL
    1,385
    new cars are an issue not just for the ITAC, but for the bulk of the club. when stock-esque examples of pony cars are keeping pace with the ground pounding, purpose built tube frame cars at the top of the speed spectrum of our classes, you know you have reached a tipping point. currently, mid level economy car "hot hatch" varients (GTI, Civic Si) will fall into the top levels of IT, Prod, ST and middle of Touring, assuming those classes allow the cars at all given turbos and hybrid drives and the like that are creeping into such cars. current sports cars don't fit ANYWHERE other than the "FAST, big money" classes in SCCA (T1-3, GT1-2). when a car that should exemplify "affordable sportscar" has no where to go without creating a franken motor or listing a very limitted number prep level options, such as is the case with the nearly 15 year old 350Z , we have a problem.
    we can't just offer further-limitted prep options to class the cars alongside 40 year old borgwalds, we need to recognize the speed creep and add classes accordingly. this, in an era when consolidation is all the rage. every car (within reason, a bugatti doesn't have to fit in our sandbox) should have prep options from stock to GT and have a place to play and have a shot at being competative. we need to rethink how we do things in a big way.
    2nd gen RX7s, NB miatas, and EG/K/M or DC hondas aren't going to be available forever. they are poised to become the next spridgets and annoy the hell out of our kids as symbols of anchoring the classes, resisting change, and being irrelevant to the current state of automobilia.
    TrackSpeed
