2000 Spec Miata (56K on chassis straight chassis, no accidents)
Built methodically from November 2012 to June 2013.
SCCA Logbook with 2014 Annual.
Five race weekends which includes double dipping in SM and STL/ITS for four weekends and the WGI 4 hour enduro on the fourth weekend. There were also four test days, three at Mid-Ohio, one at Nelson (break in) and one at WGI. All total 20 hours of run time.
Berg Racing custom 1.5” DOM cage with NASCAR bars extending to the door skins. I am 6’ 4” and fit very well. Light and safe.
Race Engineering Engine hand picked by Bob Thornton (strong motor). Header was handpicked and flowmatched with downpipe (new and no longer available from Mazdaspeed).
New hoses and clamps throughout. New alternator and coil. More new stuff that I have forgotten.
Saul Speedwell (Mark Bennett) rebuilt transmission.
Balanced and minimum weight flywheel
ACT three puck sprung clutch disc with HD pressure plate. Spare three disc un-sprung clutch disc included.
Saul Speedwell Torsen Differential setup.
Saul Speedwell Front Bearing with “special” grease
Saul Speedwell handpicked rear bearings
Fully powdercoated subframes and suspension members with specific bushings replaced for performance.
SM Mazdaspeed legal suspension purchased from Advanced Autosport. The correct bumpstops.
All new balljoints and tie rods.
Full rebuilt and powdercoated brake calipers
Goodridge braided SS brakelines.
Cobalt pads.
C&R Aluminum Radiator
Springfield Design exhaust
Panic Motorsports A/F fuel pressure regulator (AEM)
Magnecor plug wires
NGK-R plugs
Schroth HANS belts FIA rated expire in 2018
Safecraft Kevlar C5 center net with quick release.
Custom fitted driver net with latch release.
Push button solenoid kill switch (Continental Cup style)
ESS pull-type rechargeable fire system.
Seat not included.
Sparco Alcantara steering wheel
NRG 3.0 quick release
Momo Hub
Panoramic Mirror (Allview)
New windshield.
Driver footwell plate (5x racing) with heat protective material on underside of the chassis.
Center armrest included and very neatly and cleanly packaged. Interior is fully painted.
AIM Pista 05 Data Acquisition with full digital dash and GPS. Full data inputs include: water pressure, water temp, oil pressure, brake pressure, fuel pressure, TPS, steering position, fuel level (Iron Canyon Motorsports) and rear individual speed inputs (not installed yet).
12 wheels including Kazeras, TD2’s and others and many used tires included.
This car is fast and well sorted. Body has some very light scuffs. Right front headlight mount has mounting tab crack but works fine.
Numerous spares including alternator, front subframe, hubs, uprights, suspension members.
Just raced at the IT Spectacular on Aug 8-10. Ran as high as 2nd in 47 car National Level field until tires grained.
Taking a break from racing due to kids and work. Child in pic not included in sale. :-)
Price: $24,500 with AIM system ($4000 system)
$22,500 no AIM
Car is located in Rochester, NY.
Email at [email protected] or Call at 5-eight-five, 2-3-three, nineteen forty-2SM1.jpgSM2.jpgSM4.jpgSM7.jpg
