written. Thanks !
written. Thanks !
adam,
look for a 4spd and use that 1-2 set with ZC 3-4-5 or ZC 3 Si 4 ZC 5. puts 2-5 in a good tight range. same setup works wonders in the FP hatch with a 4.7 and quaiffe, ~150 whp, huge drag.
My thought was the previous interpretation was "Gear set" = all of the gears in the case.
i.e. you can stick a NB Miata gearset into a RX7 box. the whole gearset, not just 1 or 2 gears. However, that was a year or two ago and the phiolsophy may have changed now. Write the letter as Greg mentioned (and you did.)
Please post response.
Houston Region
STU Nissan 240SX
EProd RX7
3-5 is about all you need during he race but a good #2 for the green flag is necessary as well!
I also thought STL specifically only allowed complete box range swaps, AND that the difference between STU and STL language on the matter was the proof of that. Rules could have been merged, more and more I also have lost interest in the class, despite it being what I always wanted to see: limited prep rules allowing engine swaps in same make chassis.
