When we wrote "gear sets" I believe we intended that to mean gear pairs, meaning you can mix-and-match gear ratios within the box.
Write a letter to be sure.
written. Thanks !
adam,
look for a 4spd and use that 1-2 set with ZC 3-4-5 or ZC 3 Si 4 ZC 5. puts 2-5 in a good tight range. same setup works wonders in the FP hatch with a 4.7 and quaiffe, ~150 whp, huge drag.
My thought was the previous interpretation was "Gear set" = all of the gears in the case.
i.e. you can stick a NB Miata gearset into a RX7 box. the whole gearset, not just 1 or 2 gears. However, that was a year or two ago and the phiolsophy may have changed now. Write the letter as Greg mentioned (and you did.)
Please post response.
Houston Region
STU Nissan 240SX
EProd RX7
3-5 is about all you need during he race but a good #2 for the green flag is necessary as well!
