They're sure saying "no" to a normal sized TIR on the SR20DET!
Houston Region
STU Nissan 240SX
EProd RX7
It's not going to exist until you take the handcuffs off. not going to spend money to build something that's hobbled from day 1. I'll never have the cash to build a 'full-tilt' engine to prove it can't make equivalent power, and until that's done the old stodgies that hate JDM are going to continue to keep the handcuffs on a 20 yr old engine. can't win that one, so not going to try.
Houston Region
STU Nissan 240SX
EProd RX7
this is the part of "The Process" in IT that drove a number of people off, unhapily. there has to be some noise cancelation, the rulesmakers can't be jumping at every request by moving specs up and down, but there also needs to be a reasonable threshold to being taken seriously. when ONLY full tilt builds will be accepted for review (or when the perception is that this is the case), those who simply can't afford that effort are left out to dry with what are often reaosnable requests for adjustment or review. The difference between a good build and a great build is not a huge amount of peak hp in most cases, just a lot of reliability, driveability (area under the curve), etc... and it adds up to lower lap times more than winning the race on the dyno.
the ST non USDM market rules adding weight or reducing TIR size "just because foreign" is not good practice. Yes, there are specific cases (i.e. powerplants or chassis) where such penalties ARE warranted and I think any reasonable person would agree to them. but not blanket application to all items sharing a non technical detail. have your cake and eat it, too. Matt has every right to feel that way, IMHO. no one should be asked to prove a negative, and anyone who is has good reason to feel slighted.
Neither the CRB nor the STAC (nor I) has made a proclamation that "no" consideration will be made until data on a full-tilt build is presented to them.
However, there's absolutely zero point in making chances until someone builds one*.
We can always go back to "US market engines only" if it'll make people feel better...that way there's no ambiguity.
* If you truly believe that 2mm of TIR will make that much of a difference, enough so that you'll not even consider building it, then IMO it's not going to be a competitive package anyway...
"Gear sets" are the entire package, not each gear pair. per rule 2014 spec.
. Otherwise you penalise the car with non splined gear boxes.
i couldnt find any definition for "gear sets" in the GCR....
so we'll wait for the clarification, i guess.....your interpretation obviously differs from many others....but i can see both directions (or i wouldnt have made this post, and thus written a letter)
I see/saw it all the time when people are/were asking for help for a particular car. "we believe that engine will make 30%. you only make 25% so you must be doing something wrong. keep trying and come back when you spend more money and still can't make 30%."
This engine with a stock T28 turbo will NEVER be competitive with 20-year newer technology and way better turbos, but it's a farsight better than the current KA that's sucking air through a crappy intake manifold and tiny throttle body that can't be changed. My plan for an SR20 build was intended as a cheap way to get CLOSER to the competition, and I don't intend to build it to the limits. However, if its going to just be choked down from day 1 then why even bother spending thousands only to still get beat by the same people that already beat me?
I'll quit beating the dead horse and let these guys get back to the topic- it's not going to get me anywhere anyway..
Houston Region
STU Nissan 240SX
EProd RX7
letter reviewed and response out on 20th...excellent
