Results 1 to 20 of 21
Thread: Cage Pad Question
    Sep 2008
    FL.
    1,384
    "Hopscotch weld" basically you spot weld and move around the plate until you get enough tacks to be continuous or near so.
    Spark/initiate on the heavier plate and melt onto the tin in short burst. Move an inch or so and repeat . around the plate.
    That lets the weld cool between hits and will burn through less often. looks like poopsie tho but is strongerr than continuous burn weld due to less brittleness .
    Feb 2002
    Gainesville, GA
    493
    Thanks Mike. Once again it's good to be reassured it looks like poopsie. I must be doing it right.
    Jan 2010
    Houston-ish
    932
    I basically do it the way Mike mentioned as well.
    Another way when you have more access is to keep the arc on the plate and let the weld puddle kinda 'drip' down onto the sheet metal. gotta move quick enough that you don't blow through the sheet, but I had good luck with that welding the plates to the floor.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Nov 2007
    248
    Quote Originally Posted by Matt93SE View Post
    I have used the same method as above and it works but does take a bit of practice to get the right balance.
    1988 ITA Scriocco 16V #80
    MCSCC member since 1988
    Feb 2002
    Gainesville, GA
    493
    I've had good luck with that method on the floor pans and other accessible areas too. The u!
    Ultimate challenge is the upside down seam with a little bit larger than perfect gap. Talk about ugly! Fortunately it is a hard to see as it is to weld.
    While we are all sharing secrets, what settings does everybody use for the above techniques? Settings for the thicker plate, the sheet metal, or something in between?
    I've tried all with varying success using slightly different techniques for each. Just curious what people's preferences are.
    Slightly Higher than for sheet metal
    Jan 2010
    Houston-ish
    932
    Quote Originally Posted by backformore View Post
    All depends on the welder..
    or are you talking about what setting do I use to perform the plate-to-sheet weld? In that case, it's 'hot enough to melt the plate, not hot enough to burn the sheet.' usually it's a middle of the road thing on my welder.. I'll run the sheet metal current and a lower feed speed so I can get enough penetration on the plate, then just move across the sheet a bit faster to keep from overheating it. Seems to work OK for me. YMMV.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Jun 2001
    Elkridge, MD
    303
    I haven't actually done a test to confirm this, but my suspicion is that a stitch welded plate on top of thinner sheet metal is stronger and more resistant to punch-through than a continuously welded seam. When you weld you change the metallurgy and likely also affect the thickness of the sheet metal immediately adjacent to the weld for the thin sheet and I suspect that the stitch welds result in a lower residual stress concentration around the welded areas. Anyway, needs a well documented test to prove.
    When welding a thicker plate to thinner sheet metal you need to build up heat (by lingering with the torch, using a slower feed speed in a Mig) in the thicker material to ensure penetration in that piece, and then "draw" the arc & the heat onto the thinner sheet to actually make the weld. With practice avoiding blowouts is not too hard once you have fine-tuned the voltage & feed speed. It is not too hard when you are welding the edge of the thick material on top of the thinner sheet. The opposite situation is harder but fundamentally the technique is the same.
    Washington DC Region
    Scuderia Tortuga
    MARRS ITC Scirocco #12
