Quote Originally Posted by backformore View Post
While we are all sharing secrets, what settings does everybody use for the above techniques? Settings for the thicker plate, the sheet metal, or something in between?
I've tried all with varying success using slightly different techniques for each. Just curious what people's preferences are.
All depends on the welder..
or are you talking about what setting do I use to perform the plate-to-sheet weld? In that case, it's 'hot enough to melt the plate, not hot enough to burn the sheet.' usually it's a middle of the road thing on my welder.. I'll run the sheet metal current and a lower feed speed so I can get enough penetration on the plate, then just move across the sheet a bit faster to keep from overheating it. Seems to work OK for me. YMMV.
