Results 1 to 20 of 399
Thread: What is a "touring car?"
Threaded View
  1. #11
    Aug 2005
    1,717
    Not to dissuade lower-displacement efforts -- I'm really looking forward to Adam's efforts -- but it just seems that in STL higher-horsepower wins. Equal horsepower will go to the better chassis (e.g., Miata, RX-8, etc). If you have both then you're invincible. Granted, it's Road America, but in the last two Runoffs I predicted the order of finish based solely on estimated horsepower, and I've been correct. I predict the podium for Laguna Seca will go to the highest-horsepower cars this year as well, with more nods to sports cars*....
    This points to the failure of the straight weight/displacement method of determining competitiveness. So, I'd argue that other than classing the not otherwise classed, it's time to move on to spec lines for at least motors, and leave the reminder of the modifiers in place. Maybe even make a flow chart so that Tech has a coherent way to check ultimate weight.
    I put this in my request #14859.
    WRT the 'what do you think', I also need to be more educated on what the SCCA has done in the past. STL has the same 'issue' as other classes. I bet EP and FP also have the same 'issue'. Getting some success stories from the Prod ranks on how they have attempted to balance Miata's, Preludes, 240Z's, Integra's, 2002's, S2000's, RX8's, Caterham's, 914's, 944's etc.
    Seems like the concepts may already live inside the CRB.
    Don't forget that in GT/Production the open cars get to remove their windshield's and have asymmetrical cages to minimize air drag and top weight. So the ST spec roadster (even with a hard top) would be slower than the GT/Production version. Prather has the data to prove it as well.
    http://prodracing.com/prodcar/viewto...15691&start=10
    STU BMW Z3 2.5liter
