Results 1 to 20 of 399
Thread: What is a "touring car?"
    Feb 2003
    1,106
    I am wondering if RWD is the proper criteria.....
    or should it be F/R weight distribution? 50/50 is base case and 60/40 gets a 5% reduction.
    Is it the driving location or the benefit of distribution that contributes the most to the sum of the parts?
    Dec 2008
    1,391
    it's a LOT of things. RWD is a characteristic, not an inherent behavior or capability. ditto FWD. that some platforms have more of the good and others less while sharing drive wheels and some other adjectives is the issue that's hard to address without naming names.
