Results 1 to 20 of 399
Thread: What is a "touring car?"
    Dec 2008
    1,391
    And we have talked about this too. We know perception can swing the pendulum. But I refuse to allow that swing to happen based on top level SM's beating up on low level STL cars. It's short sighted and those people who bitch about SM's in STL need a reality check. They should NOT be faster than you. Use them as a bogey for development. Once you pass them, then get another target.
    If we are talking about REAL STL Miata, then I continue to ask where the data is that shows this dominance. As you said, the Miata effect (TME) can bring top drivers in top cars to the surface quickly and it can affect perception...but it shouldn't to the people in the know. Drago has a top car and it's driven extremely well. He was run with, and out-qualified by on a power & handling track, a FWD Honda with restrictions. This does not address our 'apples to apples' issue in my post above, but to say that currently the Miata's can't be beaten is silly.
    Maybe the pendulum has to swing so far the other way that the numbers look stooopid good for FWD. Then you get them built, and adjust the other way for parity?
    1 - specifically referring to STL miatas, not SMs running in STL, and the huge influence from the knowledge of SM on all miatas in SCCA, from GTL down.
    2 - there are more than one problem in STL. the overly generic chassis designations for weighting purposes (i.e. the late civics are good FWD strut cars effectively running light) and flattening of the power curve as the displacement approaches the 2.0L limit are OTHER problems. don't confuse "really fast civic" with "miata problem", and I promise you the perception of really fast civic is less troublesome to many than miata.
    anyhow, I have a job to do...
    Northeast
    7,031
    More good stuff Chip. I hesitate to try and slice up 'good strut' and 'bad strut'. If the late Civics are struts but they are really good, then so be it. It's just something that has to be dealt with. 'Warts and all' can go both ways. 'Better than on paper' can be applied to anything.
    And I also agree with the general sentiment of point 2. Just not sure how to fix. If the club is losing TC's to other clubs 'because SCCA Miata' and there is a large enough pocket of members to create a class for, then let's do it!
    New England Region 188967
    Dec 2008
    1,391
    no slicing. identify significantly strong chassis and add weight to them. "soup" as they say.
    ...I refuse to allow that swing to happen based on top level SM's beating up on low level STL cars. It's short sighted and those people who bitch about SM's in STL need a reality check. They should NOT be faster than you. Use them as a bogey for development. Once you pass them, then get another target.
    Nobody - I think, and certainly not me - is arguing from that point of view, Andy. My personal bogey very quickly became the class frontrunners in the NE, most of which happen to be the tiny handful of real STL-spec Miatas running. My proposal was VERY clear about that. I don't particularly like the idea of using other classes/categories as field fillers but there's exactly NO excuse for an SM beating up on a "real" STL car. The class structure should be - and is currently, I think - set up so that those "participatory," "double dip," or "give it a try" entries are not truly competitive.
    I KNEW going in that, as soon as I crossed the Regional/National barrier, that we're in competition adjustment territory. (Note that I don't even put a "bleah!" in there when I type it in this context.) That said, I'm convinced that the "better than the sum of its parts" or "better than on paper" part of the puzzle can largely be encapsulated in the definitions associated with what makes a sports car a "sports car." It's a proxy variable but it should be a pretty good one, as it takes a number of hard-to-measure factors into account.
    We shouldn't have to wait until a particular sports car has beaten up on every other option to put lead on it - thereby, as it happens, clearing the top of the podium for another make/model with inherent advantages over the pedestrian 4-seaters. We SHOULD design a class that's got as many make/model options as can be practically put on a relatively level playing field. I personally don't have any real issue with Miatas but I DO have a huge concern with the Club limiting the appeal of its racing program by giving them - and other 2-seaters - another place where they and their 2-seat friends bring a pretty fundamental relative advantage to running at the pointy end.
    Asheville, NC US
    1,626
    Sometimes you need to give drivers a real reason to build a new car, toss them a bone so to speak.
    Look at ITR when it started. Many people were very excited to see a car they loved on the list and wanted to build one. Then the weights came out so stupid high that any car other than an E36 made no sense. Had those other cars been given a more realistic weight there would be more diverse builds to compare, and possible adjustments made for any overdog. It is a huge money and time commitment to build a new car and won't happen unless it looks pretty darn good on paper.
    Seems like a good time to toss a bone to the FWD cars in STL if you want the class to grow. I "helped" with some of the cars you are talking about but racing alone sucks. Need to do what is needed now to make the class attractive or "concord" will get you too.
    Steve Eckerich
    ITS 18 Speedsource RX7
    ITR RX8 (under construction)
    Northeast
    7,031
    I think we need a better definition of what is the real physical trait we are trying to get a handle on. I submit it is NOT 2 seats. I submit it is RWD with DW's at both ends. Del Sol's, Capri's, Fiero's...all pedestrian. RX-8's, not pedestrian. Then you have the tweeners (cars that don't fit either category)...2nd gen RX7, 944, 968, etc.
