Results 1 to 15 of 15
Thread: changin classes
    Mar 2013
    13
    Default changin classes
    if I wanted to run in multiple class what other classes could I run in?
    production: fp, hp-class 2 or are there just those
    Mar 2001
    Connecticut
    7,381
    Build a class-compliant ITB car and you can run the following classes without changes:
    - ITB
    - STL
    - STU
    - FP
    - ITE*
    - ITEZ*
    *Division-specific
    Jan 2010
    Houston-ish
    932
    Don't know what your car is specifically, but if it's built after 1985, you can run it in STL if it's below 2L and STU if it's above 2L. IT cars are allowed in Super Touring in their IT trim (or as modified per ST rules).
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Mar 2013
    13
    its an 85 jetta, converted to mega squirt, bored 20 over, port polish 1" intake, header with resonator, balanced/blue printed bottom end
    Sep 2008
    FL.
    1,384
    Add ;HP and vintage
    Mar 2013
    13
    thanks guys really appreciate it.sorry for asking the dumb question. but on cam shaft, for production can I change them? I read unrestricted but what about duration?
    Buffalo, New York
    2,942
    Get an old Miata...run all classes on the same weekend!
    Nov 2007
    South of Chicago, near Indiana.
    248
    Quote Originally Posted by jetta1987 View Post
    What part of the injection system is controlled by mega squirt? CIS cars have to retain the stock CIS injectors to be legal for IT. You can't change to later model electronic injectors.
    You have to keep the CIS fuel distributor as well with out mods!
    1988 ITA Scriocco 16V #80
    MCSCC member since 1988
    Nov 2001
    Wheaton, IL
    1,893
    Quote Originally Posted by jimbbski View Post
    A2 cars (guessing this is an A2 Jetta by the user title) can run CIS, CIS-E or Digifant, because all of those cars are on one spec line.
    Chris Schaafsma
    Golf 2 HProd
    Nov 2001
    Somewhere in the swamps of Jersey
    399
    Quote Originally Posted by joeg View Post
    All your classes are belong to us!
    Hero To The Momentum Challenged
    Sep 2005
    Earth
    743
    Recommend Googling "SCCA GCR", and reading the IT pages. Remembering "if it doesn't say you can, you can't".
    Ed Funk
    NER ITA CRX, ITB Civic, ITC CRX (wanna buy a Honda?)
    Smart as a horse, hung like Einstein!
    Mar 2013
    13
    I actually did download the gcr at work. I just wanted to make sure I was reading the right info. and shwah thanks for clarifying on that info
    Oct 2003
    long valley, NJ
    335
    Good! It's nice to see someone who can read and understand the rules! You'll be fine.
    phil hunt
    Nov 2001
    Wheaton, IL
    1,893
    And just in case you are totally new to the class - that means the Megasquirt is A-OK, provided it has stock injectors, and other hardware (except those explicitly allowed in the rules - ecu, tps, fpr).
    Chris Schaafsma
    Golf 2 HProd
  15. #15
    Mar 2013
    13
    yes I am using stock rail, injectors , dist, and fuel pressure regulator
