Results 1 to 5 of 5
Thread: VW parts liquidation, call me if you need any blocks, A1,A2 bits
    Sep 2008
    FL.
    1,384
    Default VW parts liquidation, call me if you need any blocks, A1,A2 bits
    25yrs. of VW race junk, 1.6 blocks x2, 100$ each.
    1.8 blocks 20$
    2.0 block 25$
    A 1 parts , Scirocco parts and shells . No rabbits
    A2 Golf and jetta shells .
    A3 Jetta shell -100$ each
    Tons of old crap- if you have a VW we have something for you.
    Scrapping stuff as we write this. Please call me . Thanks, MM
    Mar 2001
    Connecticut
    7,346
    Quote Originally Posted by Flyinglizard View Post
    ...if you have a VW we have something for you...
    Jack, handle, and lug nut tool for a Beetle, to fit into the rocker panel slot on my 914...?
    Not my circus...not my monkeys...
    Nov 2001
    Somewhere in the swamps of Jersey
    398
    Greg, you're looking for real VW carp, not this late model, post '73 H2O stuff. I always said water cooling, the engine in the wrong end of the car and more than eight wires would never catch on.
    Hero To The Momentum Challenged
    Sep 2008
    FL.
    1,384
    Crushed the air crap. You might try the mid 80s Audi alloy jack . I have a few of the steel ones. None of the 19mm wheel nut wrench .
    Also found, good Mk 3 ,2.0 complete , minus distributor , 250$
    86 Volvo B 23 complete , 100$
    Complete 82 VW 1.7 with FF trans , stil in car. 400$ the fuel rail hadpressure in it.
    Quiafe , 3.94 trans RTR, 850$ (I use welded)
    Autopower
    Bolt in cage , Mk 2-3 used but nice. 500$
    many stock 14 in wheels . 20$ each .
    R 32 LCA bushings. 2 for 30$
    Strut housings. Mk 1 , mk 2, 50$ each
    many stock exhaust manifolds. 10$ each some are the big single,
    Fuel injector lines , many, 10$ each
    Still have my good running HP Golf. 4000$ RTR . many fresh items , top 3 car on hohos
    99 SM Miata , now is 8000$ as it goes faster the price goes up.
    Sep 2008
    FL.
    1,384
    Last call on the Jetta shells. 100$ each, one 97, one 88
    34604 FL.
