Results 1 to 1 of 1
Thread: HP Volkswagon Golf GTI
    Oct 2003
    Mentor, Ohio
    138
    Default HP Volkswagon Golf GTI
    Brand new 12:1 Limited Prep 1.8 liter Motor
    Wiseco flat-top Pistons - .040 overbore
    Lightened, balanced & knife edged crank
    Balanced assembly
    Fresh bearings
    ARP bolts
    Adjustable cam gear
    LP prepped head with 5-angle valve grind
    Baffled oil pan
    Windage tray
    H.D. oil pump
    Oil cooler
    Lightweight flywheel
    VW Motorsport CIS fuel distributor
    Adjustable fuel enrichment
    Welded GTI gearbox
    Spare gearbox with Quaife LSD
    New 6 puck racing clutch by South Bend Clutch
    New Racing pressure plate
    Brand new 10 gallon cell
    All new Aeroquip fuel lines
    3 qt Accusump oil accumulator w/manual valve (not installed)
    Kirkey seat
    New belts
    Optima battery
    Car has just been fully rewired with switch box (all systems set on separate fuses)
    Autometer gauges
    Autometer shift light
    MSD 6AL Ignition
    Pertronix electronic distributor
    Lexan windshield
    Rear brake proportioning valve
    (4) 13x6 BBS mesh wheels w/ mounted bias ply slicks
    (4) 13x6 BMW mesh wheels w/ mounted radial slicks
    (4) 14x6 VW Spiderweb wheels w/ IT tires
    (4) 14x6 VW Bottlecap wheels w tires rain treads
    (4) 14x6 PCW 5-spoke wheels
    Extra tire sets
    Coil overs
    Koni struts
    Adjustable front camber plates
    Solid motor mounts
    HD bushings
    Wink mirror
    Manual control fire system
    Tons of spares and miscellaneous parts
    $6500.00
    Open dual axle trailer also available
    Contact John at 440-290-7090 (h) or 669-9841 (c)
    Attached Images Attached Images
    John
    #07 ITA Nissan NX2000
    Mentor, OH
