Results 1 to 10 of 10
Thread: Rear spoiler question
    Jan 2013
    1
    Default Rear spoiler question
    So I've read the STU rules ten times over minimum, but out of curiosity have yet to find anything on rear lips or NASCAR style spoilers.
    Are these legal within the width and minimum height rules? Maybe an inexpensive option for a slight downforce gain?
    Thanks!
    A member requested explicit allowance for rear deck spoiler a couple years ago. Response in March 2012 Fastrack:
    "NR: Thank you for your letter. Rear deck spoilers are not compliant in Super Touring per GCR 9.1.4.D.2"
    GCR Technical Glossary:
    Wing – An aerodynamic attachment to the structure of a car specifically intended to generate downforce from the action of air flowing over the upper and lower surfaces, creating a pressure differential.
    Jan 2006
    Florida
    50
    Thanks Greg.
    Just want to clarify.
    If I have a Second Gen RX7 that comes from the factory with a rear spolier, I have to remove it IF I build the car to STL specs. However, IF I run the car in ITS trim in STL, I can keep it.
    Thanks
    Wayne
    Wayne Hussey
    36 ITS RX7
    SCCA Florida Region
    http://prostuning-net.webs.com/
    Not exactly. If you have a 2nd-gen RX7 that comes from the factory with a rear spoiler, you have to remove it IF you choose to install the (non-mandatory) STL-compliant rear wing. Otherwise, it can stay.
    Jan 2006
    Florida
    50
    Thanks Greg. One last question.
    I am considering moving from ITS to STL in my second gen RX7. If I am reading the rules correctly, I can run my RX7 in STL trim at a wieght of 2589, no porting but I can run any flywheel I desire.
    Thanks
    Wayne Hussey
    36 ITS RX7
    SCCA Florida Region
    If you prep it as a fully-compliant ITS car, you run ITS weight.
    If you deviate in any way toward STL prep, the 13B weighs 2589, plus you have to add 5.5% for rear wheel drive.
    No porting.
    "Alternate flywheels are permitted. Flywheel material shall be ferrous or aluminum and the ring gear diameter must be the same as the OEM flywheel."
    "Any clutch disc and pressure plate of OEM diameter may be used. Carbon clutch components are prohibited."
