Ok this leads me to my next question.
2. Rotors -
Any 1- or 2-piece ferrous rotors that do not exceed 290mm
in diameter and 28mm in thickness are permitted.
3. Calipers - Any 4-piston or fewer calipers may be used.
So if we can run any 4 piston caliper and ferrous rotors up to 290x28 which is most certainly bigger than what most of the car in this class come stock with. And you can't go with OEM (not same model) knuckles/hubs to get the bigger brakes to fit OE.
Are we then allowed to run adapter brackets that come with every big brake kit on the market to get the caliper in the proper position.
I still think the EG and DC2 are the same, you can mix and match parts between them like legos.
Wait so the integra type R is legal as long as you don't use it's engine...
This is the coolest class in scca, but damn is it confusing.
Cool thanks Greg!
I think your safest option for meeting GCR STL rules here to build yourself a 94 Civic EX/Si with ABS. It will still be 4 lug, but you will have a larger front knuckle (which BTW is the same as any non-Type R DC models), larger bearings, larger rotors/calipers (upgrade from 9.3" to 10.2") or get the Wilwood upgrade kit (11" or ~12.2") which needs the larger knuckle from the ABS model, larger brake booster and larger master cylinder. As tGA says, the Si/EX models came with disc rears, so that is an easier conversion.
'92 Honda Civic Si
PS. There are bolt-on calipers from Wilwood now for the Si/EX models with ABS knuckles. Look up Forged DPHA.
http://www.wilwood.com/BrakeKits/Bra...back+SI&whl=15
'92 Honda Civic Si
So if you have a cx could you swap in si/ex knuckles and brake booster and master cylinders since they are both civics?
