Results 1 to 6 of 6
Thread: Max Compression Ratio in STU....
    Aug 2005
    1,717
    Default Max Compression Ratio in STU....
    Am I going crazy, or will the maximum compression ratio be bumped up a 1/2 point next year to 12.5:1? I though I read it in a fastrack, but now I can't find it.
    I ordered a set of 12.5:1 pistons, but can add 0.030" to the head gasket and drop it that 0.5 point. I need to know so that I can order the correct head gasket.
    Thanks,
    7,379
    Nope, no plans to change compression ratio...don't know where you saw that. - GA
    Aug 2005
    1,717
    Thanks Greg,
    I'll get the thicker head gasket. That's crazy because, E-production has the exact same compression ratio and cam limits, the only differences are h-beam rods and dry sump oil system.
    7,379
    What "same"? 12:1 or 12.5:1?
    Rods are free and 3-stage dry sump is allowed in STU.
    - GA
    Oct 2006
    192
    Thanks Greg,
    STU allows replacement rods, pistons and dry sump systems.
    you could also shave down your piston tops if it is a domed/pyramid type.
    Aug 2005
    1,717
    Thanks Eric, I figure that a +0.030 thicker MLS gasket ought to lower the compression by 1/2 a point. At this point I don't want to mill the dome as I'd then have to have the top ceramic treatment redone.
