Crap can rules, R5/13
The intent of these rule guidelines; Allow crapcans to cross over to SCCA with little hassle. The basic car should be able to be purchased for around 1000$
AS long as the car is deemed "safe" they should have a class under these rules. The Normal IT safety rules apply, master switch, brake lights. Most "crapcan" master switches are placed within driver reach, in the center of the car.
Three classes addresses one of the few shortcomings of Chumpcar,IMHO. A stable class structure may slow the speed creep and allow a car to remain competitive for more than a couple of years .
SCCA IT cars are legal and may run with the spec tires,@ IT weight.
Stock throttle body Production cars may be legal, with the spec tires, @ Prod weight..
CCU; 2.3 and under class , 225 max tire width
CCO; class(2.4 - 3.1) E 30 BMW -6 cyl , Honda products with V tec . E 30 must be stock and uncut.
245 max tire width
CrapCan-AM; Anything over 3.1, or a non stock power train,( swapped ,boosted etc )
All 6 cyl E 36. E 36 must be stock and uncut. No max tire size.
Non stock throttle body area; = 1 class bump
Any brakes within 1 in. OD of stock.
All tires; tread wear rating of 180 or higher. Any wheels.
IT fire bottle rules.
Stock tank or fuel cell allowed.
Fuel cell required if tank is less than 20in from rear bumper, IE; BMW 2002, C4 Corvette, etc.
IT cage rules are the minimum. Production Car cage rules encouraged. Any tubing allowed between the front and rear fire walls. Attachment to the sill/rockers are encouraged. Driver side wheel house bar recommended.
No tubing past the wheel hubs.
Some exceptions will occur, small short cars like the Honda, Miata, where the rear stays must go past the wheel hubs.
Open cars; must use arm restraints or some form of roof panel. Cars with no windshield, must use arm restraints.
Driver door must have window net.
Aero; unrestricted. Must be well attached.
3 in ground clearance rule, (includes all aero panels.)
Bodywork; Hood may be gutted and vented but must remain.
Interior Body panels may be lightened.
Trunks, hatches, roofs, may be removed or gutted.
Fenders , doors, rear quarter panels, may be modified but must remain.
Exterior driver door panels may be rolled down.
Glass may be removed. "Lexan" may be used throughout. GCR, Productions sizes.
Anything that can be removed per normal "Crapcan rules" , may be removed. (Everything).
Battery placement is open. must be safe secure and covered.
Nothing is cast in stone. Please reply with suggestions to improve these. And or oversight.
Thanks, Mike Ogren, [email protected]
