Results 1 to 16 of 16
Thread: Ring and Pinion
    Jul 2004
    Raleigh NC
    3,682
    Question Ring and Pinion
    The GCR states:
    "a. Any final drive ratio is permitted provided it fits the stock differential/transaxle housing without modification to the housing."
    Now, do we collectively take this to mean any ratio, meaning, any ring and pinion of any shape and size, as long as it fits in the factory housing? So one could use a ring and pinion out of unobtainium, a skeletonized ring and pinion, or one that wasn't based on the factory OEM gears at all but fit into the housing?
    Oct 2010
    Bessemer City, NC
    47
    one would come to that conclusion...the rule, in this case, is clear.
    That is to say, it's the size of your pumpkin, not what's in it
    SEDiv CCR
    ITA92 Miata
    Matthew 19:26
    Oct 2002
    Wandering the USA
    1,341
    The 2nd gen RX-7 is a good example of this allowance. The 5.12 gear was never available for this car, and was never manufactured with an input shaft that works with the long housing in this car. To use it, you need to cut the long shaft off a donor gear and the short shaft off the 5.12 and weld the pieces together.
    Marty Doane
    ITS RX-7 #13 (sold)
    2016 Winnebago Journey (home)
    Oct 2004
    Asheville, NC US
    1,626
    Keep in mind Ron that it must fit with no changes to bearing race area, etc. No machining to add different bearings, or clearance for larger ring gear. Basically it can be made from scratch to fit the original working area. And yes, we do this for the second gen with 2 pinions cut and welded to make one and they slip into the original bearings with no mods.
    Also note that differential is open so you are not limited to ID of ring gear or bolt circle.
    Steve Eckerich
    ITS 18 Speedsource RX7
    ITR RX8 (under construction)
    Oct 2010
    Bessemer City, NC
    47
    If the ring and pinion fit, you must acquit
    SEDiv CCR
    ITA92 Miata
    Matthew 19:26
    Jul 2004
    Raleigh NC
    3,682
    Quote Originally Posted by seckerich View Post
    Yep, no changes needed. My question is aimed and making the assembly lighter. The 7.5" axle is light duty in Ford speak, but compared to a ring and pinion out of say a R180 or R200, this thing is monsterous. Ring and pinion bare weighs 18 lbs, more than twice what the same parts weigh from a R180. So, one could do something like this:
    Dec 2008
    Orlando, FL
    1,391
    legal. AND if you can find a way to pull out even more material, it's still legal. I'm wondering how far you can/will go with this. you always seem to take it to 11, and it's a lot of fun to watch.
    Oct 2004
    Asheville, NC US
    1,626
    Yes they could. Just make sure they know what they are doing and use the proper machines. Otherwise it will warp and the gear will not mesh properly. Ring gears are hardened to rc 58-60 or so I hear.
    Steve Eckerich
    Dec 2001
    raleigh, nc, usa
    5,252
    I'm putting together a new rear end package for next year, and have the LS and the R&P on the way.
    These guys backcut the ring gear and REM the R&P for $350:
    http://www.innovatorswest.com/REM-gear-polishing.html
    Moser and others will do it as well but I've seen mixed results reported on the web.
    NC Region
    1980 ITS Triumph TR8
    Jul 2004
    Raleigh NC
    3,682
    Quote Originally Posted by Chip42 View Post
    Sort of like this?
    There are some R&Ps that just don't have much material to remove. The Z R180s don't have a lot of meat. I assume Jeff's does, but I've not seen one. Stangs don't have that problem, the R&P is quite hefty.
    Dec 2001
    raleigh, nc, usa
    5,252
    Yes, mine looks basically like that (before cutting).
    NC Region
    Jul 2004
    Raleigh NC
    3,682
    These are done via electrical discharge machine. I have talked to some shops that machine them, but as Steve says, the hardness of these things is pretty high and machining would take a lot of time. Looks like the standard fare is to EDM them for weight reduction, stress relieve them via heating or peening, then to polish them to remove any imperfections.
    Oct 2004
    Asheville, NC US
    1,626
    Quote Originally Posted by Ron Earp View Post
    Sort of like this?
    Lightening like this picture is done for mostly drag racing. The webs that stick out will foam the diff oil and burn one down pretty quick in road race conditions.
    Steve Eckerich
    Jul 2004
    Raleigh NC
    3,682
    I was just talking about that yesterday at the office. I think if it is lightened it should be radially all around with no paddles since the flats won't be doing the oil any favors. On the other hand, the videos with the transparent rear differential cover show a pretty dire situation with oil flying around in the housing.
    This one looks pretty good:
    And this one might be a bit extreme:
    I also saw some that were castellated around each bolt hole. The oil would run into the castellations and I figured it'd get frothed up quickly. Hmm, Google images is failing me on that one.
  15. #15
    Purcellville, VA USA
    902
    I would be lying if I told you I had never done that to a ring and pinion..........
    Tex Racing will perform that service for you. Have them REM it when they are done also.
    Chris "The Cat Killer" Childs
    Angry Sheep Motorsports
    810 417 7777
    angrysheepmotorsports.com
    IT,SM,SS,Touring, and Super Touring
  16. #16
    Sep 2008
    FL.
    1,384
    One of my old racer buds makes these,
    http://www.ebay.com/itm/NASCAR-Gleas...2f0125&vxp=mtr
