I ran Nitto NT-01's in that size (same tire as a Toyo RA1). Very durable but not the grippiest. They say you can get up to 30 cycles out of them but they are only a UTOG 100. The hoosiers/Hankook will be UTOG 40 or less.
If you can fit 205 Hossiers then you can fit 225 of most other tire brands with ease. ITA CRX I have came with 205 Hoosiers so I went with 205/55 R14 for the first set of tires. When I bought tires last year after some research I bought 225/50 R14 Hankook Ventus Z214 C51's (non-autocross tire). Was recommended to the Hankooks by a few other CRX drivers. Tires fit great and performed well.
List up to ~20 heat cycles which is quite a few more than the Hoosiers. The tires had good grip and responded well.
I bought them off tire rack for ~$160 a tire.
