is it possible to cut the signal wire coming from the distributor TFI module so that the ECU doesnt see your rpm's so that during racing you dont hit the factory rev limiter? reason for asking is because when you do hit it during racing you have to bring the rpm's down below 3000 rpm in order for it to reset itself.
