Results 1 to 8 of 8
Thread: Cracked head ?
    Tampa Fla
    430
    Default Cracked head ?
    I run a ford 2.3 in ITB and was wondering what are the signs of a cracked head? Lately the number 3 plug is very wet with oil. There is now compression loss or overheating but there is some blue smoke that comes out of the exhaust from time to time. Could it be valve seal?
    Sep 2012
    107
    could easily be oil control rings or valve seals I'd say
    Nov 2007
    South of Chicago, near Indiana.
    248
    I agree on the valve seals or rings. Most cracked heads are found on the turbo models as they run hotter and on engines that have been overheated due to lack of maintainence.
    1988 ITA Scriocco 16V #80
    MCSCC member since 1988
    Tampa Fla
    430
    Thanks guys. I'll check and replace the seals as that can be done without removing the head.
    Sep 2008
    Weare, NH
    483
    Attached Images Attached Images
    Glenn Lawton
    GSMmotorsports
    #14 ITS RX7
    NARRC ITS Champion 2012
    NERRC ITS Champion 2013 12 11 10 09 08
    NERRC STU Champion 2010
    __________________
    Dec 2005
    Western New York
    159
    Default Cracked head....not usually.
    Manny,
    Best guess problem area is the stem seals, if you have them. Some Ford 2.3 did not use stem seals, just the stem/guide clearance (being cast iron, it works for a while).
    Best procedure is to remove the head, and knurl the guides for proper clearance, check the seats for cracks (while it's off), and regrind seats and valves for best sealing.
    Cure the leak, and improve performance for a more trouble free season!! What a deal.
    Or run a hotter plug to deal with the oil.
    Good racing,
    Bill
    Bill Frieder
    MGP Racing
    Buffalo, New York
    Sep 2012
    107
    Quote Originally Posted by lawtonglenn View Post
    I see what you did there ............haha
    Tampa Fla
    430
    thank you Bill. I can allways count on you
