Results 1 to 16 of 16
Thread: Seat Question/Concern
    Feb 2008
    601
    Default Seat Question/Concern
    Hello everyone, happy 2013.
    My RX-7 has a Kirkey seat in it that was in it when purchased. I've used a few other Kirkeys before in track cars and really like them, but this one does not have as much "rib" support as the others did.
    Upon further inspection, I'm worried that the seat is a drag race seat due to the low sides. My plan had been to buy head and shoulder supports and move the seat a little lower and add a little lay back to it, but looking at Kirkey related material I started to think it's probably a drag seat and am double thinking all of that now.
    So I have two questions really. If it is indeed a drag seat, is it safe for road racing with those attachments? It's in an IT7 car, so low HP/fairly lightweight but I hate to say "it's slow so safety isn't as important." That's simply not true.
    If it's NOT safe, I'm looking at two alternatives. First is the Kirkey road race intermediate seat and the second is a "generic" FPR seat. I like Kirkey because they're able to be modified and with a seat back brace required for non-FIA seats I have just always THOUGHT that an aluminum seat may react better in a crash than a fiberglass seat attached to the cage.
    I've heard horror stories of aluminum seats before though just as I've heard stories of fiberglass/plastic seats cracking and what not. The craftsmanship on the Kirkey road race seat looks top notch though and solid for my platform, but I'd like some second opinions as well.
    Thanks!
    -Simon
    Sep 2001
    hampden,ma.usa
    3,083
    Actually you should do some research on the Kirkey seats. The ones with the tight rib supports are usually circle track seats. I think those do more harm than good in a shunt. The road race seats I have seen have good support at the hips and the shoulders.
    dick patullo
    ner scca IT7 Rx7
    Feb 2008
    601
    Yeah I read many people saying those rib protectors weren't that great. This has pretty much no rib protection, it looks very similar to this seat:
    http://www.jegs.com/i/Kirkey/570/41700/10002/-1
    Here's my seat, but the cover is wrong so it LOOKS like it has some rib support but the actual seat isn't sticking out in those wing flaps all the way:
    Feb 2008
    601
    Now I've found some other track day/racers that use the drag seat because of the less "rib" protection. Looking at the thickness and design between the Drag and Intermediate seats with the larger wings, they don't seem too different.
    raleigh, nc, usa
    5,252
    Should be a number on it somewhere. Call Kirkey and ask them what you have.
    Jan 2010
    Houston-ish
    932
    Pull the cover off and the number will be on a sticker or engraved in the shoulder area.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Feb 2008
    601
    Yeah it faded off quite a bit I can't really make it out, Kirkey told me to send them a photo of it so I'll see what they say.
    Feb 2008
    601
    Ha. I did find a readable sticker on it now.
    Looks like it's a 20 degree Economy, looking closer at it, it appears as though someone cut down the rib protectors some, which would explain why the cover doesn't fit the wings there (I just thought it was the wrong cover).
    Still awaiting Kirkey's thoughts on adding anything to it though.
    Jan 2004
    raymond NH
    623
    Dont add anything to that seat. Get the Road Race one.
    After beating myself up in an Economy seat for years and buying a car with the road race seat. I wont go back.
    And at 6' 7" a road race seat mounted to the floor and cage is far enough back for me to fit. Tried an FIA Hans seat this fall and cant get low enough in the chassis to clear the roof,main hoop, shut the door, put up the net. Its a small akward interior in a seven.
    Dan 77 IT7
    it7racing.com
    Feb 2008
    601
    Yeah I have decided that I'm ditching it for another seat. I'm considering the Kirkey road race containment seat and the Kirkey Intermediate road race. I've also looked at a few fiberglass/plastic type seats but am unsure on the whole seat back brace size of them.
    Nov 2004
    Lilburn, GA
    597
    I have a 58 series Kirkey seat. I find the seat comfortable and it holds me very well. I like the rib supports, but I had my seat custom built so the supports are in the right places. I have it mounted to a custom frame that attaches to the cage and basically sits right against the floor like Dan. I'm 6'5" and need all the head room I can get.
    ITA 240SX #17
    Atlanta Region
    Mar 2004
    Toronto
    135
    I have a circle track seat that I cut down the sides on, but not as much as yours
    . My elbow kept hitting it when shifting.
    Joe Camilleri
    HP Scirocco
    Check out the VW Club Racers Facebook page: http://www.facebook.com/group.php?gid=309326556818
    Feb 2008
    601
    Quote Originally Posted by Dano77 View Post
    Dan 77 IT7
    Do you have the Intermediate road race?
    http://www.kirkeyracing.com/index.ph...=Series47#nogo
    I'm leaning towards that but for not much more you can have the road race containment, but biggest concern there is getting in and out of the car and having room to do so at a decent pace. lol
    Jan 2003
    Rockaway, NJ
    1,548
    Simon I'd go with a Kirkey road race seat. Designed for sports car road racing and built great you can't go wrong. Also allows for easier exit through the window if the door gets pinched shut. Ive had several cars with the Kirkey road racer in them. When I considered the shoulder and head supports I wouldn't be able to exit the window so Ive stayed with the seat as is.
    Cheers!
    BenSpeed
    #33 ITR Porsche 968
    BigSpeed Racing
    2013 ITR Pro IT Champion
    2014 NE Division ITR Champion
    Feb 2008
    601
    I ordered one yesterday. Looking forward to using it.
    Jan 2003
    Rockaway, NJ
    1,548
    Cool! Way to pull the trigger
    BenSpeed
    #33 ITR Porsche 968
    BigSpeed Racing
