View Poll Results: Who would support aftermarket coolant bottles?
Voters
25. You may not vote on this poll
  • Yes
    22 88.00%
  • No
    3 12.00%
Multiple Choice Poll.
Results 1 to 11 of 11
Thread: coolant bottle
    Apr 2008
    1,499
    Default coolant bottle
    Can we change this and the plumbing to use one or does it need to remain stock?
    I don't have a GCR with me and my phone is HORRIBLE to try and find it.
    Stephen
    Oct 2011
    Hickory NC
    19
    I use mine as an oil overflow catch can.
    Apr 2008
    1,499
    OK So I got my answer... NOT legal to remove or use an alternate overflow bottle in IT. Bummer I kinda wanted to run an aftermarket one as they are much less expensive and I could mount it near the firewall away from the front of the car.
    Oh-well Stock it shall stay!!
    Stephen
    3. Engine Cooling System
    a. Any radiator may be used, provided it is mounted in the original
    location, maintains the same plane as the original core and
    requires no body or structure modifications to install. No new
    openings created by fitting an alternate radiator may be used
    for the purpose of ducting air to the engine.
    b. Oil cooler(s) may be added or substituted. Location within the
    bodywork is unrestricted, provided that it/they are not mounted
    within the driver/passenger compartment.
    c. Cooling fans may be removed or replaced. Electrically operated
    fans with manual or automatic actuation may be fitted.
    d. Thermostats may be modified, removed, or replaced with
    blanking sleeves or restrictors.
    e. Air conditioning systems may be removed in whole or in part.
    f. Screens of one-fourth (1/4) inch minimum mesh may be
    mounted in front of the radiator and/or oil cooler(s) and
    contained within the bodywork.
    g. Engine coolant fluid, coolant/heater hoses and clamps may be
    substituted. Heater hoses may be plugged or bypassed (looped)
    or removed. Heater water control valve(s) may be added or
    substituted. Heater core shall not be removed.
    Nov 2004
    Boyertown, PA- USA
    454
    Unfortunately, *functional* replacement coolant overflow tanks are extremely rare for my car. I have substituted one (actually, the car builder did...) that is made of the same material (plastic), and is of the same*critical* dimensions (working volume) as stock. Whereas the stock bottle was designed based on working volume, and was formed irregularly for packaging reasons only, I would cite 9.1.3.C as a basis for the substitution. Keep in mind, I'm not saying this isn't a very tortured interpretation of this rule, but that's my story and I'm sticking to it. I would much prefer we allow it, as I would expect that if I were protested on this specific item, I'd likely be found non-compliant.
    9.1.3.C
    Stock replacement parts may be obtained from sources other than the
    manufacturer provided they are the exact equivalent of the original parts.
    The intent of this rule is to allow the competitor to obtain replacement
    parts from standard industry outlets, e.g., auto-parts distributors, rather
    than from the manufacturer. It is not intended to allow parts that do not
    meet all dimensional and material specifications of new parts from the
    manufacturer.
    Matt Green
    ITAC Member- 2012-??
    Tire Shaver at TreadZone- www.treadzone.com
    #96 Dodge Shelby Charger ITB- Mine, mine, all mine!
    I was around when they actually improved Improved Touring! (and now I'm trying not to mess it up!)
    Jan 2010
    Houston-ish
    932
    Matt, I would argue in your favor given the information you've stated and the rules as posted. Going from a 20lb coolant bottle to a 2lb bottle, I could understand. (i.e. my F250 holds a couple gallons of coolant and is quite thick to hold system pressure.)
    a non-pressurized expansion tank doesn't weigh much to begin with and are prone to rot. Good luck finding one in good shape for a 20 yr old car, and they're stupid expensive at the dealership- If you can even get them.
    If the factory bottle held 2qts and your replacement held 2qts and was mounted in the same location (oh noes!! he moved 2LBS in his engine bay!), then I'd argue that your replacement is within the intent of the rules and IT philosophy, and contains no competitive advantage.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Buffalo, New York
    2,942
    Remember, GCR overides ITCS. 9.3.15 states that OEM is kept when it is pressurized and working.
    My resvoir is not pressurized, so I went aluminum.
    May 2008
    CT/NY/NJ
    1,157
    Quote Originally Posted by joeg View Post
    Same here.
    Chris Rallo "the kid"
    -- "wrenching and racing" -- "will race for food!" -- "Onward and Upward"
    Jul 2004
    Raleigh NC
    3,682
    I don't think I've ever seen a stock coolant recovery bottle on an IT car. I hope I don't see a stock recovery bottle either - who wants a 10, 20, or even 30+ year old plastic catch bottle on an IT car just waiting to fail and dump water? Make your motor, drive line, suspension, safety equipment all legal and race your car.
    Oct 2005
    In the green Honda
    449
    I was using a gatorade bottle for a while because it is clear and I can actually see what is in it. But now I'm back to the stock plastic.
    We're pretty sure my coolant leak was in the solid pipe that runs from the water pump to the thermostat. Bad O-rings. Only happened when things were bouncing around so we couldn't recreate it in the garage. Jr recreated it by accidently touching the pipe.
    Jim Hardesty
    ITC 1986 Honda Civic Diablo Rojo Verde
    Never argue your tab at the end of the night. Remember, you're hammered and they’re sober.
    Nov 2004
    Boyertown, PA- USA
    454
    Absolutely not.
    1.2.3. Interpreting and Applying the GCR
    A. Interpreting the GCR shall not be strained or tortured and applying
    the GCR shall be logical, remembering that the GCR cannot specifically
    cover all possible situations. Words such as “shall” or “shall
    not”, “will” or “will not”, “can not”, “may not”, “are” or “must” are
    mandatory; and words such as “may” and “should” are permissive.
    B. References in the GCR to the SCCA Operations Manual and the
    SCCA Insurance Manual are for informational purposes; these
    SCCA documents may not be protested or appealed.
    C. Conflicts among or between portions of the GCR are handled as
    follows:
    1. The Category Rules take precedence over the General Technical
    Specifications.
    2. Specific class rules in the Category Section of the GCR shall
    take precedence over the general Category Rules and the
    General Technical Specifications.
    3. Any item not addressed in the Category Rules is controlled by
    the General Technical Specifications.
    And then, the Category tells us that you can only do what's listed, and coolant bottles are not mentioned.
    Yes, I realize it's ironic that I just helped make the case for someone who'd protest my coolant overflow.
    Honestly, I'm not sure what the point of 9.3.15 mentioning pressurized containers is. Are there pressurized ones smaller than one pint?
    So, who's going to write the letter?
    Matt Green
    Apr 2008
    1,499
    Matt,
    I see this looks like it may have passed for 2014. Just NOT the pressurized systems...
    congrats,
    Stephen
