Results 1 to 6 of 6
Thread: Engine Cutting Off
    Oct 2011
    Hickory NC
    19
    Default Engine Cutting Off
    I have an engine problem that's really got me stumped. My engine dies when making a right hand turn. It feels like your turning off the ignition. If I feather the throttle 1/4 or less it runs fine, but more throttle and it cut off. As soon as I straighten the wheel it runs normal. Also runs great when turning to the left.
    This is on a 1994 Miata 1.8 engine.
    I have checked the following:
    Fuel pressure good.
    No loose wires on engine.
    No loose wires under the dash.
    No wires touching the accelerator peddle or cable.
    I have replaced:
    Fuel pump.
    Kill switch.
    Engine computer.
    Any ideas would be appreciated.
    Thanks Vance
    Had a Miata buddy up here with a similar-sounding problem. He replaced the entire engine wiring harness, firewall forward, and it fixed his issues. - GA
    May 2008
    CT/NY/NJ
    1,157
    Regardless of fuel level I assume?
    Chris Rallo "the kid"
    Oct 2011
    Hickory NC
    19
    Yes, this happens when tank is full or less.
    My data logging computer monitors battery voltage which is solid. I also monitor the fuel pressure between the regulator and fuel rail and it is steady.
    I checked the tank baffle when I replaced the fuel pump and it was not moving.
    I thought about replacing the wiring harness. Hope I don't have to do it.
    Thanks Vance
    Oct 2005
    6
    I had a similar problem with a 1990 miata, left hand turns. Turns out the fuel filter was the cause, full of crap that blocked the flow. Replaced it and problem went away.
    Oct 2011
    Hickory NC
    19
    I took the throttle position sensor apart (destroyed it) and found a bad spot starting ar 1/4 throttle. Hope this is the problem. Bothers me it only shows up in right hand turns.
    I also going to replace the fuel filter and going to clean all the ground connections and put star washer under them. After that I will go test at a local track.
    Thanks to everyone for your help and suggestions.
    Vance
