Results 1 to 11 of 11
Thread: 2000 Civic Si Front Sway Bar
    Feb 2002
    Gainesville, GA
    493
    Default 2000 Civic Si Front Sway Bar
    A little help here. I've read so many different threads about so many different things, I can't remember what's real or even consensus.
    I am sure that I read an opinion that disconnecting the front sway bar on a particular Honda/Acura (think it was an Integra) would lead to damaged axles. Of course, with the variety of Honda/Acura suspension designs, I can't recall if it would apply to the Double A-Arm 2000 Civic Si.
    Can someone please clarify this for me. The general consensus on Honda/Acura setup is no front bar, but I would hate to have one of the exceptions that leads to broken parts.
    Thanks,
    Rory
    I have never run a front bar on the 1995 Acura Integra. No axle probs.
    Jun 2001
    LaCrosse Wis
    302
    Having a civic si bar on my teg, what's the wisdom of disconnecting it? Are you thinking about compensating with more front spring?
    Keeping the front paws on the ground, working to maximize rear roll weight transfer.
    Jul 2006
    Sunnyside, NY
    1,197
    ^ true. I also do not use a front bar on my EG with no axle problems plus I don't cook my front tires as quickly... It takes only a little to get used to and once you make the change, there's no going back.
    '92 Honda Civic Si
    Apr 2011
    13
    The Si sway bar is a REALLY thick front bar, its 26mm. If you are concerned with completely removing your sway bar you could install a 22mm front sway bar (%50 less tiff than the Si bar) from the 96-00 EX\LX Civic. If you like where that takes you than remove the bar altogether. I'll have to warn you though, you will have to do some work to get the EX/LX links to work. The Si and the EX/LX use different link types and the lower control arm sway bar link mounts are different.
