Results 1 to 3 of 3
Thread: 944 rod size ?/
    Sep 2008
    FL.
    1,383
    Default 944 rod size ?/
    Anyone have the rod dimensions? For the bearing OD??
    Thanks, MM
    Royal Oak, MI, USA
    1,599
    Con rod bush (wristpin) is 24mm. rod journal is 51.971-51.990 range when new. There's also service bearings listed at -0.25 and -0.50mm.
    Is that what you needed?
    Vaughan Scott
    Detroit Region #280052
    '79 924 #77 ITB
    #65 Hidari Firefly P2
    www.vaughanscott.com
    Sep 2008
    FL.
    1,383
    Rod bearing OD for a rebuilt rod size.
    Thanks, MM
