Results 1 to 19 of 19
Thread: July 2012 Fastrack
    Default July 2012 Fastrack
    Mar 2001
    Connecticut
    7,381
    Dec 2001
    raleigh, nc, usa
    5,252
    Much appreciated.
    NC Region
    1980 ITS Triumph TR8
    Mar 2001
    Connecticut
    7,381
    Mar 2003
    schnectady,ny.usa
    351
    I saw that all ITB Volvo's are now in ITC ??
    Or am I missing a Volvo model or two ?
    John VanDenburgh
    VanDenburgh Motorsports
    ITB Audi Coupe GT
    Omaha, NE
    316
    You're missing the 142/144.
    Ralf
    ITB Golf GT
    Jun 2001
    Elkridge, MD
    303
    That's just brilliant. A car that has run three seconds a lap faster than the ITC lap record at Summit Point that has stood for more than a decade is now moved to ITC. Wonderful.
    Washington DC Region
    Scuderia Tortuga
    MARRS ITC Scirocco #12
    Dec 2008
    Orlando, FL
    1,391
    what are the current cars (240 volvos) running compared to ITC? what was the weight then, and now as an ITC car? are you sure the summit point record is in a 240, not a 142/4? are you aware of the fact that there were known to be a large number of not exactly legal volvos in ITB around that time who have since mostly moved on or come in line with the rules?(IIRC these were 14X cars but they are simillar to the 240s. They were making too much power, call it cheating if you like, but I think it had more to do with local group rules creep beyond the book more so than any one group or racer intentionally cheating to find an advantage over the others) My point is that it's not likely to be as bad as you are making it out to be. and if we're wrong, ask the ITAC to fix it. but prove us wrong first.
    this was in fastrack for member input, complete with new weights in both B and C. we waited a few MONTHS before making the change, which was based on the recalculated, and very low, process ITB weight (unachievable, maybe by a couple of hundred lbs) or a high for the class, but achievable, process ITC weight. everyone's input is and was welcome, but we recieved nothing on this topic.
    Jul 2002
    Arlington, VA USA
    515
    Quote Originally Posted by Chip42 View Post
    are you sure the summit point record is in a 240, not a 142/4? are you aware of the fact that there were known to be a large number of not exactly legal volvos in ITB...
    This.
    The car Evan is talking about specifically is a 240. And Chip has hit it on the head. It's not often that you see an ITB car w/ more straight line speed that a good deal of the ITS cars in the same run group.
    We likely won't be seeing this car again in the MARRS series anytime soon.
    Gregg Ginsberg
    '96 Civic EX -- MARRS ITA #72
    WDCR-SCCA Rookie of the Year 2003
    MARRS ITA/T3 Drivers rep
    Nov 2001
    Bunker Hill,WV.
    614
    Quote Originally Posted by evanwebb View Post
    No one ever said that the Datsun 510 that set the ITC lap record at Summit Point was a legal car.
    Holy crap, did I just say that! The horror.
    cheers
    dave parker
    "Ignore All Confrontations With Common Sense."
    Jun 2001
    Elkridge, MD
    303
    Quote Originally Posted by Gregg View Post
    This.
    I certainly hope you are right Gregg! Especially given that the guy really couldn't drive to save his life either, even Dave Parker said he should find other pursuits! :-)
    Anyway, it's one car at one track, not enough data to base anything on but nonetheless it has me worried... especially when I see that 2700 lb brick barreling down on me!
    Scuderia Tortuga
    Dec 2008
    Orlando, FL
    1,391
    given the nature of run groups and the generally increasing weight of newer cars, you will be on track at some point with 2700# and higher cars, likely with more speed than an IT-legal Volvo 240 should ever attain. So having something "heavy" in your class shouldn't bother you at all, you already share the track with heavy cars and should have a race-length advantage in class due to tire wear. having something in your class that is too light should make you quite upset, though.
    Oct 2005
    In the green Honda
    449
    I see a 79 Volvo 240 DL registered in ITB for the upcoming MO race.
    Am I mising the IT spec line for a 79 240?
    Jim Hardesty
    ITC 1986 Honda Civic Diablo Rojo Verde
    Never argue your tab at the end of the night. Remember, you're hammered and they’re sober.
    No you aren't missing anything that car is now in ITC???????
    Les Chaney
    #33 FP Volvo
  15. #15
    Oct 2005
    In the green Honda
    449
    Quote Originally Posted by Harvey View Post
    So it's likely a 79 242/244 not a 240 and will be running in ITC.
    Jim Hardesty
  16. #16
    That would be my guess since a 242 is nothing more than the 2 door version of the 240 series car.
    Les Chaney
    #33 FP Volvo
  17. #17
    Dec 2008
    Orlando, FL
    1,391
    Its still up to the entrant to know what class his car is in. Many people don't keep up with the rule changes.
  18. #18
    Oct 2005
    907
    Or that's the car in his garage and he registered it but intends to run something else. I've seen RX7's registered in ITB and when the driver gets to the track, he just changes the class at registration.
  19. #19
    Feb 2002
    402
    I'm a bit late here, but there are some errors with the line items. The 2.0L B20 engine is OHV, not SOHC as listed in the new line item. Also the wheel base increased to 104.3" in 1979, so the 3rd line item needs correction too.
    If the newly classified specs for the 240 are not supported by track data (i.e. the cars are too fast for ITC), then a re-look is part of the normal process. Time will tell.
    Last edited by rsportvolvo; 10-01-2012 at 03:25 PM. Reason: added wheelbase line item comment
    David Russell
    IT Volvo 242
