(I wonder if Dick is bias in any way? <_<)
Busting balls,
Mickey
'92 Honda Civic Si
Trying to figure out these ST rules for a friend... I am not sure which of the 3 options are legal.
1.)Can I run an ITR legal Mazda RX8 in STL at 3000lbs?
2.)Can I run a renesis engine in an ITS,A,B,or C car at 3000lbs no matter what kind of car it is?
3.)Or can I only run the RX8 as an STL car with all STL requirements like fuel cell, 17" x 7" rims ect...
If I have other options please let me know... kinda confused at this point as the onlyt thing that is clear is that "The Mazda Renesis engine is permitted at 3000 lbs"
Thanks,
Stephen
No. ITR-spec cars are not compliant to the STCS.
Yes, as long as it's a Mazda, with RWD adder as appropriate, and as long as it's compliant to all other open ST regs (e.g., Renesis in a first-gen RX-7 will require an FIA-spec fuel cell). It is *not* compliant under the ITCS allowance (unless there's an ITA/B/C/S compliant car that uses the Renesis).
Yes, at 3000 pounds plus the 2.5% RWD adder. Make sure the stock cams are within class limits.
Just Great!
Now I have to find some new camshafts for my rotary!
Rodney Williamson
www.titaniummotorsports.com
Can I run in any st class as a world challenge car? That way I dont have to add a fuel cell? Needing a fuel cell eliminates any RX8 from ever participating.
