Results 1 to 4 of 4
Thread: Rules question
    May 2008
    CT/NY/NJ
    1,157
    Default Rules question
    Why would they do this?
    Why not change 9.1.3.D.2.b.?
    just curious... thanks!
    From the GCR, 9.1.3.D.1.s-9.1.3.D.2.e.
    "s. To allow commonly available engine mount aftermarket
    inserts, replacement units, or “window weld” like solutions
    without allowing solid metal or rigid materials or bearings that
    could result in the driveline becoming a stressed member of
    the chassis, the following is permitted. Engine, transmission,
    differential or any other driveline mounts may be replaced.
    Mounts may use only stock mounting points, must maintain
    stock location and orientation of the mounted component, and
    must be non-rigid.Rubber or other inserts in stock mounts may
    be replaced with any other non-metallic material.
    2. Rotary engines (only)
    a. Any porting or polishing is prohibited.
    b. Rules D.1.a.-k., and D.1.m.-r., also apply.
    c. Crankshaft pulley is unrestricted.
    d. Alternate rotor seals and springs are permitted.
    e. Alternate mounts are permitted as in 9.1.3.D.1.s."
    Chris Rallo "the kid"
    -- "wrenching and racing" -- "will race for food!" -- "Onward and Upward"
    Dec 2001
    raleigh, nc, usa
    5,252
    Not sure I understand the question. Are you unsure as to why they change was made in that section of the rules rather than another?
    NC Region
    1980 ITS Triumph TR8
    May 2008
    CT/NY/NJ
    1,157
    Why not change 9.1.3.D.2.b. to read "b. Rules D.1.a.-k., and D.1.m.-s., also apply."
    Dec 2008
    Orlando, FL
    1,391
    That's CRB-added, and I guess they missed 9.1.3.D.2.b.
    a cleanup is in order, no doubt.
