Looking for a float that will stop the left hand stumble , I was told that an early mazda float will work, one that is not cut on an angle. Has anyone converted the float into the nikki carb. And is there a part number for this float . Thanks
Have you read the technical article about the carbs on sterlingmetalworks.com. One discussion of the stumble problem can be found WAAAAAAY down the section found here:
http://sterlingmetalworks.com/the_sterling_nikki.htm
Read the whole article, as well as the rest of the carb articles, if you haven't already. Lots of great info on his site.
I did , they didn't have a part number. That is a great site .
