Results 1 to 5 of 5
Thread: MK3 Rear Strut Tower Modification
    Default MK3 Rear Strut Tower Modification
    What are you guys doing when mounting rear shocks in your MK3?
    The options I see right now are:
    - Use poly inserts instead of the factory rubber ones (what I have been doing)
    - Modify the strut tower to accept a spherical bearing (what I have been thinking)
    If you have any suggestions/pictures I'd appreciate them!
    Disclaimer: my MK3 is raced in NASA GTS, no ITB. It also has a 1.8T swap.
    On MkIs we have used both the spherical and the poly upper rear shock mounts. I think this is one of the few places where poly bushings are Ok for a race car. I wouldn't use poly on any suspension part that rotates such as a control arm bushing. I would save the money on the rear mounts and start with the poly.
    Tom Broring
    Wash DC Region
    ITA Nissan Sentra SER
    HP Triumph Spitfire
    HP VW Rabbit
    Wheaton, IL
    1,893
    Just keep using factory rubber. It is not performing any suspension locating function.
    I am using sphericals there, simply because I needed to make the 'stack' thinner due to the amount of threaded rod available on my shock shaft.
    Chris Schaafsma
    Golf 2 HProd
    Quote Originally Posted by T Broring View Post
    ... I think this is one of the few places where poly bushings are Ok for a race car. I wouldn't use poly on any suspension part that rotates such as a control arm bushing. I would save the money on the rear mounts and start with the poly.
    I agree completely. We installed aftermarket poly bushings and haven't touched them since.
    Thank you guys. Poly strut mounts it is!
