Page 1 of 11 123 ... LastLast
Results 1 to 20 of 207
Thread: December 2011 Fastrack
    Jan 2008
    Laurel, MD
    106
    Jul 2006
    Sunnyside, NY
    1,197
    Thanks David... I think they got the displacement incorrect for the 2012 Honda Civic Si. It should 2.4, not 2.0.
    Demetrius Mossaidis aka 'Mickey' #12 ITA NESCCA
    '92 Honda Civic Si
    STFU and "Then write a letter. www.crbscca.com"
    2013 ITA NARRC Champion and I have not raced since.
    Jan 2008
    Laurel, MD
    106
    You are correct. The displacement should be 2354 (that got shoved into the wheelbase which should be 2620/2670 (2dr, 4dr). It may be too late to fix that for the December Fastrack, but we'll get it the next time around. Thanks for noticing.
    Dave
    Mar 2001
    Connecticut
    7,381
    Full version up (and thread title adjusted accordingly...)
    http://www.scca.com/assets/11-fastrack-dec.pdf
    Mar 2001
    Connecticut
    7,381
    Rules passed for 2012:
    #3193 – Add a new 9.1.3.D.9.n as follows: “Windshield washer systems, rear windshield wiper systems, cruise control systems, horns and the wiring associated wiring with any of these may be removed. Any holes left in the body must be covered or plugged.”
    Wheel rules changed:
    #3426 – In 9.1.3.D.7.a.1 change as follows:
    Cars may not fit wheel diameters larger than those listed on their spec line. Knockoff/quickchange type wheels are prohibited. Wheels must be made of metal.
    [All ITS/ITA/ITB/ITC cars currently listed in the ITCS with a wheel size less than 15 inches would be changed to 15 inches. All ITR cars currently listed in the ITCS with a wheel size less than 17 inches would be changed to 17 inches. The heading on the wheel size column would be changed to “Max Wheel Diameter”.]
    #3749 - In 9.1.3.D.9.c, add the following at the end: “Switches to activate the ignition, the lights, the windshield wipers, the starter and other accessories located within the passenger compartment may be replaced and their location changed.”
    (multiple) - In 9.1.3.D.1, add a new subsection s as follows: “To allow commonly available engine mount aftermarket inserts, replacement units, or “window weld” like solutions without allowing solid metal or rigid materials or bearings that could result in the driveline becoming a stressed member of the chassis, the following is permitted. Engine, transmission, differential or any other driveline mounts may be replaced. Mounts may use only stock mounting points, must maintain stock location and orientation of the mounted component, and must be non-rigid.Rubber or other inserts in stock mounts may be replaced with any other non-metallic material.”
    In 9.1.3.D.2, add a new subsection e as follows: “Alternate mounts are permitted as in 9.1.3.D.1.s.”
    Jul 2006
    Sunnyside, NY
    1,197
    '92 Honda Civic Si
    Feb 2003
    Grove City, OH, USA
    1,449
    Can we interpret 9.1.3.D.7.a.1 to mean that cars that are listed with 15" wheels can run 14" or 13" wheels?
    Bill Stevens - Mbr # 103106
    BnS Racing www.bnsracing.net
    92 ITA Saturn
    83 ITB Shelby Dodge Charger
    Sponsors - Race-Keeper Data/Video Aquisition Systems www.race-keeper.com
    Simpson Performance Products - simpsonraceproducts.com
    Trussville, Alabama, USA
    1,087
    APPLAUSE!!!! Chuck
    Chuck Baader
    White EP BMW M-Techniq
    I may grow older, but I refuse to grow up!
    Buffalo, New York
    2,942
    Forgot Charcoal Cannisters...geez louise...
    8,607
    >> Body – All parts of the car licked by the air stream and situated above the belly / floor with exception of the roll bar or cage. (GCR Technical Glossary)
    That big hole resulting from removal of the washer bottle is going to let a lot of nice cool air in from inside the fender.
    Apr 2008
    1,499
    Damn.. waisted $50 bucks last year on one that I used for 3 races I didn't even realize it was up for a rule change. Oh well I need to lose some lbs so this helps
    Stephen
    Dec 2008
    Orlando, FL
    1,391
    Quote Originally Posted by RacerBill View Post
    thats how I read it. have fun trying to find affordable 13x6 wheels, and please let me know if you do!
    Jul 2004
    Raleigh NC
    3,682
    Dammit, just when I start building a car that has cold air induction from outside the engine bay as stock.
    May 2008
    CT/NY/NJ
    1,157
    interesting...
    Chris Rallo "the kid"
    -- "wrenching and racing" -- "will race for food!" -- "Onward and Upward"
  15. #15
    Flagtown, NJ USA
    6,335
    Not IT related, but I find it interesting that they threw out the 2.5 participation rule yet again to save T3, but "the CRB has no intention of returning GP to the GCR"
  16. #16
    Jan 2008
    Laurel, MD
    106
    Quote Originally Posted by Bill Miller View Post
    The BoD made the decision to retain T3 in 2012, not the CRB.
    Dave
  17. #17
    Royal Oak, MI, USA
    1,599
    Cool...
    Vaughan Scott
    Detroit Region #280052
    '79 924 #77 ITB
    #65 Hidari Firefly P2
    www.vaughanscott.com
  18. #18
    So after all the arguing, haranging, harassment and ridicule
    for the damages of rules creep, we can now legally remove our windshield washer bottle and defunct horns and use custom, non rigid driveline mounts?
    Ya know, we're all starting to look a lot like congress.
    John W8
    CSP10 Miata
    ITA50 Miata
  19. #19
    Jul 2004
    Decatur , GA, USA
    183
    Best bunch of rule changes I've seen in a long time. I was just about to send in what I expected to be another no-hope request to allow deletion of washer bottles, and what happens? Thank you!!
    Tom Lyttle
    Decatur, GA
    IT7 Mazda - 2006, 2008 SARRC Champion
    ITS Nissan 200SX - finally running correctly
    FP Ford Capri - waiting for a comp adjustment
    GT3 Dodge Daytona - what was I thinking?
  20. #20
    Nov 2001
    Wheaton, IL
    1,893
    I don't like the motor mount rule.
    I don't like the wheel rule.
    I am ambivalent to the horns/washers/etc rule.
    I would rather see the charcoal canister get addressed over all of these...
    Chris Schaafsma
    Golf 2 HProd
