Results 1 to 1 of 1
Thread: AIM Evo 4 and Mychron3 dash and data acq system
Threaded View
    Nov 2011
    5
    Default AIM Evo 4 and Mychron3 dash and data acq system
    For Sale
    AIM EVO 4 data acquisition system like new with original packaging, instructions, cd-rom and all wiring.
    Included in the system is an optional Mychron3 Dash display with gear indicator, shift lights and 4 programmable warning lights.
    New ECU/OBD-II port data cable for Subaru/Saab 92X ecu.
    Description:
    EVO4 is the latest system from AiM. EVO4 is a compact, standalone logger that has GPS and a 3-axis accelerometer built in. While it is great as a portable unit that can be easily moved between vehicles, it also has all the features you would expect for a permanent installation, such as 5 analog channels, 2 speed inputs, CAN ECU and expansion capabilities, and the ability to add external displays.
    EVO4 Features:
    • Integrated GPS
    • Integrated 3-axis accelerometer
    • 5 analog input channels
    • RPM input
    • 2 wheelspeed inputs
    • 8MB of non-volatile memory
    • GPS Lap Timing (Capable of using infrared lap beacon, beacon and receiver not included)
    • Sampling rates: digital inputs up to 50 Hz, analog thermocouple up to 100 hz, analog potentiometer up to 1000 Hz
    • CAN/Serial (RS-232) interface to connect to ECUs
    • Compatible with CAN expansion modules such as GPS, SmartyCam, LCU-1 Wideband, Channel/Thermocouple Expansion, and Memory Key
    • Fast USB download to your PC and Race Studio 2 Analysis software
    Dash description:
    MyChron3 Dash for EVO4 Features:
    • RPM Graphical Display with configurable scaling
    • (1) Selectable display field for RPM, speed, best lap time or battery voltage
    • (2) Selectable display fields for analog inputs; a button on the display switches to a second page with 2 different measures
    • Last Lap Time
    • 10 LED Shift Lights (green, yellow red)
    • 4 LED Alarms, fully configurable for minimum or maximum alarms
    System has been sold
