Results 1 to 11 of 11
Thread: Are COPs legal?
    Jan 2005
    Alachua, Florida
    261
    Default Are COPs legal?
    I'm planning on changing my '94 miata over to the Toyota COPs and I think it's legal but I figure I'll check with the experts before I take the plung.
    Steve Elicati
    ITA 1994 Mazda Miata
    Central Florida Region
    Mar 2001
    Connecticut
    7,381
    Negatory, Batman.
    We had this discussion just a couple months ago (was it here or on RRAX?) and the rule, as stated:
    Any ignition system which utilizes the original distributor for spark timing and distribution is permitted.
    ...does not allow it. With CoP the spark distribution is no longer being done by the distributor; ergo, CoP is not compliant to the IT regs... - GA
    Jan 2005
    Alachua, Florida
    261
    crap. thanks
    Steve Elicati
    Since the Miata has a distributorless ignition system the Cam Angle sensor sends the signal to the coils when to fire. So in this case I would think the Cam angle sensor would be considered the distributor. As long as it's still there and not replaced with a crank trigger why would that be illegal?
    John W8
    CSP10 Miata
    ITA50 Miata
    Mar 2001
    Connecticut
    7,381
    Quote Originally Posted by JohnW8 View Post
    Ok, different horse, then. That's right, I forgot my '94 had that double coil-pack on the back of the engine.
    spark timing and distribution is permitted. Internal distributor
    components and distributor cap may be substituted. Crankfire
    ignition systems are prohibited unless fitted as original equipment.
    Any spark plugs and ignition wires may be used. Ignition
    timing is unrestricted.
    I.T. is "IIDSYCTYC" (If It Doesn't Say You Can Then You Can't). Coils are not mentioned, but they are currently being freely replaced under the "any ignition system" clause. My logic:
    - "IIDSYCTYC", first and foremost.
    - "Any ignition system" invokes the Roffe Corollary to "IIDSYCTYC", or "If it Says You Can, Then You Bloody Well Can!"
    - "...which utilizes the original distributor..."; not relevant. "Distributor" does not apply to this car.
    - "Crankfire ignition systems are prohibited..."; not relevant.
    On re-thought, due to the engine not having a distributor, and that the ignition is otherwise free (as it pertains to this engine), I'm game to say CoP on this car is, in fact, compliant to the ITCS regulations.
    GA
    Thanks Greg.
    I wasn't sure I could remember where I hid my original Mazda coil setup if I had to change it back.
    John W8
    CSP10 Miata
    ITA50 Miata
    Jan 2005
    Alachua, Florida
    261
    thanks greg and john for clearing this up.
    Steve Elicati
    Mar 2001
    Connecticut
    7,381
    You're welcome, and remember: this is only one person's opinion, and a very unofficial (yet highly enlightened ) one at that. - GA
    Jan 2005
    Alachua, Florida
    261
    gotcha. i'll delay cutting and hacking my wire harness for a couple of days and am open to other opinions as to the legality of this mod.
    Steve Elicati
    Jan 2010
    Houston-ish
    932
    Quote Originally Posted by pitbull113 View Post
    gotcha. i......am open to other opinions as to the legality of this mod.
    Everyone is entitled to their opinion, even if it is wrong.
    Houston Region
    STU Nissan 240SX
    EProd RX7
    Buffalo, New York
    2,942
    ...unless the distributor has any rubber in it!
