I'm one of those "if it ain't a 4X4, it ain't a real truck" people; but then I do use my truck for way more than just towing; like getting around in the snow, or getting to the top of mountains on dirt trails maybe 2' wider than the truck. So, my perspective may be a little skewed.
I will say, I have had to use 4WD once or twice in the paddock at Summit - back in the grassy areas in the woods, or back near working camping it can get pretty slick after a rain. But in general if I were buying a truck only for towing I probably wouldn't worry about 4WD. I would just avoid those areas where I might get stuck.
Earl R.
240SX
ITA/ST5
yea, it's all about where you live.
I was never a 4wd guy, thought it was a waste. "Man up and get some snow tires, throw some sand in the bed, disconnect the rear sway bar and just drive", LOL
I must be getting old. This last winter was brutal around here. one 12" storm followed by a 16" storm, record breaking long before it was over, and I needed to get around. Since you can not BUY a 2 wd truck in CT, LOL, my new truck came with 4WD.
Ummmm....it's errrrrr....GREAT. One late night coming home I was the only guy out on the Merritt parkway. It was DUMPING 2 or 3" per hour. The road was 12"+ deep, unplowed. I won't tell you how fast i was going. But i wasn't crawling, LOL. Sadly a tree was down across the whole road (It was a helluva storm) so I had to turn back and drive the wrong way. Only guy I came across was a cop, who had chains on and was struggling with those.
On I-95, cars were abandoned in the middle of the road...jeeps even!
So, yea, I'm a believer.
But I can not remember ever engaging 4WD in that truck while the trailers hooked up.
So, for towing, I'd skip it. But don't drive into slippery paddock areas.
If you race @ Nelson, get the 4wd..
MM
I live in Houston.
Snow? What's that? If it does snow here, all of the overpasses are iced over and the highways are closed so you just stay home and watch the idiots on the news.
Hills? You mean the freeway interchanges? You can see about 25 miles from the top of the big ones.
Mud? why bother. there's always a paved way to get there since most of this place used to be rice paddy or swamp.
Houston Region
STU Nissan 240SX
EProd RX7
That is funny to hear that you've come to the dark side Jake!! LOL I always remember you bustin' on 4x4!! I've got one of those jobs that is NOT considered non essential (I work for a hospital) and MUST get to work no matter how much snow. Yup, there was once this past winter I was driving through 28" of snow on unplowed streets........... I was lovin' my 4x4 that morning!!!
Jeff L
ITA Miata
2010 NARRC Champion
Little late for a reply, but figured I'd chime in if somebody else comes across this thread.
I did the 4x4 vs 2x4 research when I got my 2002 F350. Wound up going with a 2x4 as I didn't want to deal with the maintenance that comes with the 4x4s. One thing I didn't know, though, is that the front brakes are different between the 2x4s and 4x4s. All those spiffy performance rotors you see for the F350s are only if you have a 4x4. The rotors on the 2x4s are part of the hub. If you want to replace the rotors you have to replace the whole hub. I've done it. The brakes on the truck I bought had a vibration (turned out one of the calipers had completely frozen slide pins) and I figured it would be an easy task just to swap rotors. Wrong. It wasn't too bad, but swapping a hub is much more than just swapping rotors. I did use new bearings when I did the job so the front end should be good for as long as I own the truck.
ITA 240SX #17
Atlanta Region
I have been to some tracks where I would have been stuck in the grass paddock if I didn't have 4WD. also in really heavy rain I feel the truck to be more stable and safer in 4WD.
i would get the 4WD, and it helps with resale.
Kevin Anderson
I really like the 4x4 option - have had it on three tow vehicles now and when you need - you need it! Now being in the Great State of Texas.....I dunnno. I would still opt for it IMHO.
ez
